pgw Posted May 15, 2012 Posted May 15, 2012 Hi, Does someone know how I can make the revision cloud in Autocad 2002. Does it have the function? In which meny is it? What is the short command? Quote
MSasu Posted May 15, 2012 Posted May 15, 2012 (edited) There should be the RCLOUD command. Edited May 15, 2012 by MSasu Wrong answer Quote
pgw Posted May 15, 2012 Author Posted May 15, 2012 aha, well I tried it but did not work, but I saw the tread was edited afterwards... Quote
MSasu Posted May 15, 2012 Posted May 15, 2012 Sorry, I have mistakenly read the join date (2012) as your AutoCAD version. On AutoCAD 2002 the revision cloud was available as part of Express tools pack - you may not have that installed since for that version it was sold separately. However you can download and use a third-part AutoLISP routine. Quote
eldon Posted May 15, 2012 Posted May 15, 2012 Do you have the AutoCAD DesignCenter? Type ADCENTER at the command line and see if the DesignCenter window loads up. If it does, then you can drag the revision cloud into your drawing. If not, then the Revision Cloud was in Express Tools. Quote
ReMark Posted May 15, 2012 Posted May 15, 2012 RevCloud was one of the Express Tools lisp routines but ET was not included with AutoCAD 2002. It had to be migrated over from AutoCAD 2000/2000i. You'll have to find a custom lisp routine written by someone else that will do the same thing. Should be fairly easy. Quote
pgw Posted May 15, 2012 Author Posted May 15, 2012 Hi, thanks for your tips, I will see if I can find this LISP routine. Quote
MSasu Posted May 15, 2012 Posted May 15, 2012 I will see if I can find this LISP routine. Please check the link on post #4. Quote
