spittle Posted October 29, 2008 Posted October 29, 2008 I'm working on a couple of drawings made up mainly of 5 XREFs, each averaging between 20 & 30 MB. The drawings using these XREFs are taking an age to open and they keep freezing on me whilst working on them, often for around 3-8 minutes at a time. The scales have been reset throughout. The drawings and XREFs are saved on a network and in Task manager the network usage goes up into the 80s (%) whilst AutoCAD has frozen then it drops back down again when it's back up and running again. There are no messages that pop up when opening the XREFs individually. Purge has been run throughout. I'm assuming my problems are down to the large size of the XREFS. It really is becoming unmanageable. Any ideas? the XREFs just contain the background (OS) of a huge area around Gloucester either size of a proposed pipeline and they are all in DWG format. Using 2x Xeon Quad 2.6GHz 8GB Quadro FX 3700 512MB Quote
Tiger Posted October 29, 2008 Posted October 29, 2008 Hav you purged/audited the files? are they 3D? Can you make them 2D? Quote
spittle Posted October 29, 2008 Author Posted October 29, 2008 All is purged, they're not 3D either. Quote
NBC Posted October 29, 2008 Posted October 29, 2008 Would it be useful to XCLIP the xref's ? Sometimes that can help with speed issues. Quote
Tiger Posted October 29, 2008 Posted October 29, 2008 It could help to have them on the local computer instead of the network as well, if that's possible. Quote
NBC Posted October 29, 2008 Posted October 29, 2008 and / or also you may wish to visit the link below for a different solution: http://discussion.autodesk.com/forums/thread.jspa?threadID=579776 Quote
lpseifert Posted October 29, 2008 Posted October 29, 2008 Try enabling Demand Loading and/or using Xclip. Quote
spittle Posted October 29, 2008 Author Posted October 29, 2008 The Xref's are clipped where I can, will explore the other suggestions too. Thought about saving locally but would like to avoid that if poss as other people are working on drawings using the XREFs. they shouldn't really be chaging but I've made a few adjustments on them. Quote
spittle Posted October 29, 2008 Author Posted October 29, 2008 And it's not an issue with scales, they are all down to a minimum. Quote
wannabe Posted October 29, 2008 Posted October 29, 2008 Do you need to be able to measure or snap to any of the entities in the xref? Quote
