The required script will look like this (version for 3 frames):
_LAYER _S 0
_LAYER _OFF Layer1 _OFF Layer3 _OFF Layer5
_LAYER _ON Layer1
_DELAY 300
_LAYER _OFF Layer1 _ON Layer3
_DELAY 300
_LAYER _OFF Layer3 _ON Layer5
_DELAY 300
;end of script
May use Excel to create script's lines, due to the big number of frames. Please don't ignore the empty lines - those are required to end the LAYER command.
You may also want to consider my previous suggestion to use slides instead of layers.
thank you for taking time to do this :) i am really grateful :)
i tried this but only show a layer5 and stop there .. layer1 or 3 do not seeing ?
I tested the script in AutoCAD 2007 and is working well. What version are you using? Is 2012 as per your profile?
Just tested it again in AutoCAD 2011 and seems that there is an issue with command’s dialog box – it remains on screen and the view is refreshed only at the end of the script action.
But found a workaround: set the FILEDIA system variable to 0 and call the SCRIPT command in prompt mode; this way seems to work.
Don’t forget to set the FILEDIA back to 1 after since will affect other commands too.
do i haw to turn off all the other layers ( related to circles ) or leave them on .. ?
i tried both solution and in try1 where i turned off all the layers layer5 only pop up and stay .. no other layer is shown
it seams it's working after filedia .. i'll do the rest of the script .. will get back with result .. many many thx for this :)
You will have to turn them all to OFF in first step. Alternatively you may turn them by hand before run the script, but controling them by script is useful if want to run it more than once - without closing the file (to reset the layers to OFF).
Sound that you got is sorted! That's a good news. You're welcome!
Just out of curiosity, is this for a school project?
Here was one messing around using Transient graphics
ScreenCast
The code is pretty messy was just throwing it together to see how it worked, but it makes objects look animated without locking up the UI thread and can still continue to work.
Code
Another comment regarding usage of SCRIPT command in prompt mode – if you will name the script using drawing’s name (i.e. Move.DWG & Move.SCR) and place them on the same folder, then when issue the command, the default value will be constructed based on drawing’s name, so you will not have to type the path; just hit and the show will begin.
If you're still interested. both the codes i posted can be modified to do just that. the sequence will all depend on your imagination.
If you want the ball to "remain", just comment this line [on post #9]
(rolling delay)
[b][color=blue];; (hide lnm 2)[/color][/b]
or if you want to it to leave a trail.
(defun c:Roll  (/ hide Rolling Delay n)
     (initget 7)
     (setq delay (getint "\nEnter Delay factor: "))
     (defun hide  (ln mode)
           (setq ss (ssget "_X" (list (cons 8 ln))))
                 (redraw (ssname ss (setq i (1- i))) mode)))
     (defun Rolling  (prcnt)
           (repeat prcnt
                 (setq prcnt_1 (1+ prcnt))
                 (prompt "\r|") (prompt "\r/")
                 (prompt "\r|") (prompt "\r\\")
     (setq n 0)
     (hide "ROLL-*" 2)
     (repeat 29
           (setq lnm (strcat "Roll-" (itoa (setq n (1+ n)))))
           (hide lnm 1)
           (rolling delay)
          [b][color=blue](hide lnm 3)[/color][/b]
    [color=blue][b](hide "Roll-29" 1)[/b][/color]
[b][color=blue]    (setq n 0)[/color][/b]
[b][color=blue]    (repeat 29[/color][/b]
[b][color=blue]          (setq lnm (strcat "Roll-" (itoa (setq n (1+ n)))))[/color][/b]
[b][color=blue]          (hide lnm 2)[/color][/b]
[b][color=blue]          (rolling (/ delay 2))[/color][/b]
[b][color=blue]          )[/color][/b]
[b][color=blue]    (hide "Roll-29" 4)(hide "Roll-29" 2)(hide "Roll-29" 1)[/color][/b]
Try that and see how it looks. As for the Freeze/Thaw approach. the code can be modified to accept list of layers for the _FTLayer sub.
Thing is, the "animation" is only limited by your imagination mcclarion.
