MarkX Posted October 29, 2008 Posted October 29, 2008 Hi, I just assigned the task of writing a macro that needs to bring up a table when it is run that will allow the user to select an option from a drop down menu. Once the selection is made the macro needs to turn layers on and off in the Drawing that the macro is run in. Any help that you could offer would be much appreciated. Thank you Quote
borgunit Posted October 29, 2008 Posted October 29, 2008 Add a combobox to a form. To give it its choices do something like With CmbBox .AddItem "qty 1", 0 .AddItem "qty 2", 1 .AddItem "qty 3", 2 .AddItem "qty 4", 3 .ListIndex = 0 End With Quote
MarkX Posted October 29, 2008 Author Posted October 29, 2008 This is code that I found while I was looking around this site. Can this code be used for the purposes of making a form that will allow the making of options for layer selction? I believe that this was post by ASMI. (defun c:patlay(/ oldPat cFlag lLst Ans actDoc aName oldLay) (vl-load-com) (defun StoreLayerStates() (setq patlay:layerstate nil) (vlax-for l(vla-get-Layers actDoc) (setq patlay:layerstate (append patlay:layerstate (list (list l (vla-get-LayerOn l) (vla-get-Lock l) (vla-get-Freeze l) ); end list ); end list ); end apend ); end setq ); end vlax-for (princ) ); end of StoreLayerStates (if(not laypat:pat)(setq laypat:pat "")) (setq oldPat laypat:pat) (while(not cFlag) (setq laypat:pat(getstring T (strcat "\nLayer name pattern or [Help/Quit] <" laypat:pat ">: "))) (cond ((member laypat:pat '("H" "h" "_H" "_h" "Help" "HELP" "help")) (princ "\n <<< PATTERNS AVAILABLE >>> \n") (princ "\n # - Matches any single numeric digit.") (princ "\n @ - Matches any single alphabetic character.") (princ "\n . - Matches any single nonalphanumeric character.") (princ "\n * - Matches any character sequence, including an ") (princ "\n empty one, and it can be used anywhere in the ") (princ "\n search pattern at the beginning, middle, or end.") (princ "\n ? - Matches any single character \n") (princ "\n ~ - If it is the first character in the pattern,") (princ "\n it matches anything except the pattern.") (princ "\n [...] - Matches any one of the characters enclosed.") (princ "\n [~...] - Matches any single character not enclosed.") (princ "\n - - Used inside brackets to specify a range.") (princ "\n for a single character.") (princ "\n , - Separates two patterns.") (princ "\n ` - Escapes special characters (reads next") (princ "\n character literally).") (princ "\n\nPress F2 to close text scren...\n") (textscr) ); end condition #1 ((member laypat:pat '("Q" "q" "_Q" "_q" "Quit" "QUIT" "quit")) (setq cFlag T laypat:pat "") ); end condition #2 ((= laypat:pat "") (setq laypat:pat oldPat cFlag T) ); end condition #3 (t (setq cFlag T) ); end condition #4 ); end cond ); end while (if(/= laypat:pat "") (progn (setq lLst '() actDoc(vla-get-ActiveDocument (vlax-get-acad-object)) ); end setq (vlax-for l(vla-get-Layers actDoc) (if(wcmatch(strcase(vla-get-Name l))(strcase laypat:pat)) (setq lLst(append lLst(list l))) ); end if ); end vlax-for (if lLst (progn (princ(strcat "\n>>> Layers found ("(itoa(length lLst))"): ")) (princ(strcat (vla-get-Name(car lLst)))) (foreach l(cdr lLst) (princ(strcat ", "(vla-get-Name l))) ); end foreach (setq Ans "lIst") (while(or(= Ans "lIst")(= Ans "Highlight")) (initget "On ofF Lock Unlock fReeze Thaw Isolate Previouos Highlight Quit") (setq Ans (getkword "\nSelect option [On/ofF/Lock/Unlock/fReeze/Thaw/Isolate/Previouos/Highlight/Quit] : ")) (vla-StartUndoMark actDoc) (cond ((= "On" Ans) (StoreLayerStates) (mapcar '(lambda(l)(vla-put-LayerON l :vlax-true))lLst) ); end condition #2 ((= "ofF" Ans) (StoreLayerStates) (mapcar '(lambda(l)(vla-put-LayerON l :vlax-false))lLst) ); end condition #3 ((= "Lock" Ans) (StoreLayerStates) (mapcar '(lambda(l)(vla-put-Lock l :vlax-true))lLst) ); end condition #4 ((= "Unlock" Ans) (StoreLayerStates) (mapcar '(lambda(l)(vla-put-Lock l :vlax-false))lLst) ); end condition #5 ((= "fReeze" Ans) (StoreLayerStates) (mapcar '(lambda(l)(if(not(member(vla-get-Name l) (list (vla-get-Name (vla-get-ActiveLayer actDoc)) "0"))) (vla-put-Freeze l :vlax-true))) lLst); end mapcar (if(member (setq aName(vla-get-Name(vla-get-Activelayer actDoc))) (mapcar 'vla-get-Name lLst)) (princ(strcat "\nCan't freeze active layer '" aName "'! ")) ); end if ); end condition #6 ((= "Thaw" Ans) (StoreLayerStates) (mapcar '(lambda(l)(if(not(member(vla-get-Name l) (list (vla-get-Name (vla-get-ActiveLayer actDoc)) "0"))) (vla-put-Freeze l :vlax-false))) lLst); end mapcar (setvar "CMDECHO" 0) (command "_.regenall") (setvar "CMDECHO" 1) ); end condition #6 ((= "Isolate" Ans) (StoreLayerStates) (vlax-for l(vla-get-Layers actDoc) (if(not(wcmatch(strcase(vla-get-Name l))(strcase laypat:pat))) (vla-put-LayerON l :vlax-false) ); end if ); end vlax-for ); end condition #7 ((= "Previouos" Ans) (if patlay:layerstate (progn (setq oldLay(vla-get-ActiveLayer actDoc)) (setvar "CLAYER" "0") (mapcar '(lambda(l) (vla-put-LayerOn(car l)(cadr l)) (vla-put-Lock(car l)(nth 2 l)) (if(not(member(vla-get-Name(car l)) (list (vla-get-Name (vla-get-ActiveLayer actDoc)) "0"))) (vla-put-Freeze(car l)(last l)))) patlay:layerstate); end mapcar (if (and (/= :vlax-true(vla-get-Freeze oldLay)) (not(vl-catch-all-error-p (vl-catch-all-apply 'vla-get-Name (list oldLay)))) ); end and (vla-put-ActiveLayer actDoc oldLay) ); end if (StoreLayerStates) ); end progn (princ "\nPreviouos layer state missed ") ); end if ); end condition #8 ((= "Highlight" Ans) (sssetfirst nil(ssget "_X"(list(cons 8 laypat:pat)))) ); end condition #9 ((or(not Ans)(= "Quit" Ans)) (princ "\nQuit LAYPAT ") ); end condition #10 ); end cond (vla-EndUndoMark actDoc) ); end while ); end progn (princ "\nNo layers found! ") ); end if ); end progn (setq laypat:pat oldPat) ); end if (princ) ); end of c:patlay (princ "\n*** Type PATLAY for wildcard layer actions*** ") Quote
