jrn Posted May 3, 2012 Posted May 3, 2012 Scripts are not my strongest skill, so I hope to find some basic help. I want to make a action macro that selects the copy the last layout tab, copy that, goes modelspace and -pan @some numbers, go back in modelspace. stop. I've recorded the following steps succesfully: Layout copy and mspace -pan (basepoint plus some mumbers) (@-3000,0) I would like to know the command for selecting the last layout tab. Without using right-click functions which, as I know of, are not recorded? Hope someone can help Quote
BIGAL Posted May 4, 2012 Posted May 4, 2012 This is the code for getting a list of layout tabs not sure if last is first (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for lay (vla-get-Layouts doc) (setq plotabs (cons (vla-get-name lay) plotabs)) ) (setq lasttab (nth 1 plotabs )) ;or (cadr plotabs) Quote
jrn Posted May 23, 2012 Author Posted May 23, 2012 Tank you, Bigal ! I got a bit lost with the code, but I found another lo-fi time consuming practical way :-) Quote
