paduroiul Posted May 3, 2012 Posted May 3, 2012 Hi I want to import points (number,x,y,z) saved in a notepad file. How can I do this, what is the sequence of commands which I have to follow The file I want to import looks like this. cote k-lumea.txt Quote
MSasu Posted May 3, 2012 Posted May 3, 2012 (edited) One solution will be to use Excel to build a script and use SCRIPT command in AutoCAD to run it. _POINT 499990.537,499983.388,399.872 _TEXT 499990.537,499983.388,399.872 52 Please take care of multiple spaces (); also don't forget to end the SCR file with an empty line. Alternatively just do a search on the forum; this issue was discussed a lot previously. Bine ai venit in Forum! (Welcome to the Forum) Edited May 3, 2012 by MSasu Misses spaces when pasted code Quote
BIGAL Posted May 4, 2012 Posted May 4, 2012 Do you have map/civil3d if so just use the "points" menu or "Aeccimportpoints" is the command What are you trying to actually do ? Quote
