Hi all, I'm new in the forum, but it looks like there are some experts around that can share some knowledge.
My problem is the following:
I have created a macro in excel that selects a series of points and assigns them some coordinates Easting Northing and RL (X,Y,Z). Then a second macro reorganises all the data and groups it as I need. At the end it creates a script.
I'm trying to create some spheres and some 3Dpolylines from the center of the spheres.
I think I know how to do that. Since I have X,Y,Z for each point I just got the script to write the following:
_Sphere
646063,531851,111 30
text 646093,531881,111 25 0 BH21>>
For the polylines I do the same thing with 3Dpoly command.
I set my layer, I get the command Sphere, XYZ and diameter. then I add some text. From what I have seen that's the right way to do it.
The problem comes when I run the script. It creates the layers fine, it runs the command Sphere but then it crashes because it cannot understand that the numbers separated by "," are actually X,Y,Z. It keeps on asking me to specify the center point for my sphere.
I have the feeling that it may have something to do with my AutoCad settings but I'm not exactly sure what. I have searched the web and multiple forums for days with no success. I finally decided to come here and ask people with more experience than me, see if I can get someone to point me in the right direction.
Thanks to all in advance!
And you have tested these same numbers in your drawing by entering them at the command line and they work right?
Hi Guys,
Yes, if I use the sphere command in the command line and then copy paste the coordinates from Excel in the command bar it works perfectly. It is only when it comes from the script that it doesn't work.
Below I pasted parts of the script, not the whole thing because it is basically a repetition of those lines some few hundred times.
osnap
off
layer new Bore color 7 Bore
layer color 7 Bore
layer new Soil color 20 Soil
layer color 20 Soil
layer set Bore
_Sphere
_Sphere
646147,531752,105 30
text 646177,531782,105 25 0 BH12
_Sphere
646205,531732,118 30
text 646235,531762,118 25 0 BH33
layer set Soil
_3dpoly
645963, 532052, 114
645963, 532052, 113.8
layer set Soil
_3dpoly
645963, 532052, 111
Thanks for your help!
_Sphere
this space equal a enter key
try
646063,531851,111
30
text
_Sphere 646063,531851,111 30
