adt2 Posted April 26, 2012 Posted April 26, 2012 I am trying to export a curve drawn in the Right viewport to AutoCAD - where I need it in plan (Top) view. When I select the curves in Rhino and do File>Export, the curve ends up facing the wrong direction in AutoCAD (i.e. with the Top view selected on the View Cube in AutoCAD, all I see is a single line - not the outline of the part I'm working on). What's the trick here? How do I take a profile drawn in 3D in Rhino and flatten & export it to 2D for further work in AutoCAD? Quote
ReMark Posted April 26, 2012 Posted April 26, 2012 Why don't you just change the orientation of your UCS and rotate the line(s)? Post a copy of the DWG file here. Someone will take a look at it. Quote
adt2 Posted April 26, 2012 Author Posted April 26, 2012 Frame_0.dwgFetching info... Ask, and ye shall receive. This should be a roughly V-shaped figure, with the point of the V pointing down and the arms pointing up. Quote
ReMark Posted April 26, 2012 Posted April 26, 2012 Only in your imagination. I used 3Dorbit to take a look at it and could not see the "V" you speak of. When I run the Erase command AutoCAD finds six objects which are identified as splines. Quote
adt2 Posted April 26, 2012 Author Posted April 26, 2012 Figured it out. Select curves, select front view, make2d, export. Quote
