Hi geys,
First post here. Could use use Help!
This has probably be asked before, but....
How do you create a dynamic wood screw block with lookup functinality so that you can select, say, 20mm, 25mm, 30mm screws ect. ect., and both the length and threads change acordingly? Got as far as a lookup for the length with a stretch action but cant get the threads to array acordingly!
Any pointers will be great.
Many thanks.
