Hi Everyone,
I am new to AutoCAD and have just finished using AutoCAD Plant 3D to model a basic plant for my 4th year chemical engineering design project. However, every shape I have drawn has a white outline around all the edges. Is there a way to remove this so I can take a screenshot for my report.
Thanks,
Luke
Play little with Visual Styles...
Click the object and open its properties. In the general section go down to "Lineweight" and put it down to 0.00mm. I'm not sure if they disappear when you print it, but in your model space, it will reduce the thickness of your border.
I wonder if those "shapes" are the original geometry used to create the 3D objects?
DELOBJ
Controls whether geometry used to create 3D objects is retained or deleted.
