bwdeen Posted April 18, 2012 Posted April 18, 2012 As this has probably been discussed before, I'm stuck and pulling my hair out...lol the text on the right is middle-align, prefect, the text on the left is also middle-aligned but is offset. How can i fix the left text to match the right? Thanks, BW Deen Quote
Dadgad Posted April 18, 2012 Posted April 18, 2012 Use MATCHPROPERTIES enter 'MATCHPROP' at your commandline, then just follow the prompts, should fix you right up. Or you can find it on your MODIFY dropdown from the menu bar. Quote
bwdeen Posted April 18, 2012 Author Posted April 18, 2012 Thanks for the reply: I have tried MATCHPROPERTIES but its doesn't fix the "spacing" issues that appears on the left text.....just odd setting somewhere and i cant remember where.... Quote
Squirltech Posted April 18, 2012 Posted April 18, 2012 Have you tried to "remove formatting" on the text on the left? Highlight the text in the edit box. Right click and select "remove ALL formatting". Just a shot in the dark. Hope it works. Quote
Dadgad Posted April 18, 2012 Posted April 18, 2012 Are those text, they look like MTEXT. Do you have column values applied to the on on the left, causing it to leave a margin perhaps? Quote
Dadgad Posted April 18, 2012 Posted April 18, 2012 Good thought, that will probably take care of it. Quote
bwdeen Posted April 18, 2012 Author Posted April 18, 2012 ugh, are you as puzzled as I am....just removed the columns and formatting, still same. Quote
bwdeen Posted April 18, 2012 Author Posted April 18, 2012 whoa, line space style and height were slightly off....i found it of course by highlighting both items and reviewing the properties.....Thanks all for helping.... Quote
Dadgad Posted April 18, 2012 Posted April 18, 2012 All's well that ends well, glad you figured it out! :wink: Quote
Dadgad Posted April 19, 2012 Posted April 19, 2012 As is so often the case, when you get stuck, turn to somebody smarter than the average bear. http://www.lee-mac.com/matchtextprops.html I've never used it, but as a student of history, I would be surprised if it didn't. Quote
