I like to set my right mouse button to bring up the menu of available options for the current command, but more importantly, when no command is active to enable a shortcut menu.
Quite often I wish this short cut menu had the match properties shortcut in it and a few others.
So can you guess my question and answer it?
Find the Pop menu you want to edit in the CUI and add it. pretty straight forward
Yes, definitely an easy one.
The thing is, information on these forums goes well beyond the ACAD help in most cases. So I think if I dont ask you guys first I might miss out, potentially, on all the extra information :)
