transcad Posted April 18, 2012 Posted April 18, 2012 Anybody has a function to replace point with comma in strings? Quote
MSasu Posted April 18, 2012 Posted April 18, 2012 Please check the VL-STRING-SUBST function: (vl-string-subst "." "," "2,50") 1 Quote
transcad Posted April 18, 2012 Author Posted April 18, 2012 This one is ok! I have a lisp that works only with autolisp, not with Visual Lisp...and for me is easier to have a function defined in Autolisp...thanks! Quote
MSasu Posted April 18, 2012 Posted April 18, 2012 I’m afraid that both suggestions are VL functions. The only reason you should avoid using VL extension is when you are intending to use a routine in older version of AutoCAD (if I remember well, pre-2000 releases). If you really want to use only vanilla AutoLISP, then parse the string with SUBSTR and reconstruct it with STRCAT; test each character and when encounter "," use "." to the new string. Quote
pBe Posted April 18, 2012 Posted April 18, 2012 Show us the string you want to translate. (vl-string-subst ......... (vl-string-translate ..... Difference between the two is ... the latter will replace all target character on the whole string. Quote
transcad Posted April 18, 2012 Author Posted April 18, 2012 Sorry guys, it's ok with vl... is perfect! My mistake...i was thinking that i have to convert object for vl...but is not necessary... Quote
pBe Posted April 18, 2012 Posted April 18, 2012 For fun (defun _translate (str old new / a b) (while (and (setq a (substr str 1 1)) (> (strlen str) 0)) (setq b (strcat (if (null b) "" b) (if (eq old a) new a)) str (substr str 2)) ) b ) (_translate "2.50" "." ",") Quote
transcad Posted April 18, 2012 Author Posted April 18, 2012 If i have a real like 5.0 and i make (rtos 5.0 2 1) , the result will be "5" - and i need it "5.0" - how to do it? Quote
pBe Posted April 18, 2012 Posted April 18, 2012 Your Dimzin system variable is currently 8 Change to 3 or 0 or http://www.cadtutor.net/forum/showthread.php?37233-Auto-Numbering&p=468506&viewfull=1#post468506 rtos-dec sub-routine by irneb Quote
Lee Mac Posted April 18, 2012 Posted April 18, 2012 This was my take on a 'consistent rtos' function (quoted from a post at TheSwamp): ================================================== Due to variation in the DIMZIN System Variable, the rtos function can sometimes produce undesired results, even when both arguments have been specified. For example: [color=green]DIMZIN = 0[/color] _$ (rtos 0.234 2 2) "0.23" [color=green]DIMZIN = 4[/color] _$ (rtos 0.234 2 2) ".23" [color=green]DIMZIN = 0[/color] _$ (rtos -0.23 2 3) "-0.230" [color=green]DIMZIN = 12[/color] _$ (rtos -0.23 2 3) "-.23" That last example may also cause problems with applications using the read function as a method of converting strings to other data types. Usually the solution would be to temporarily change the value of DIMZIN so that the result of a conversion can be predictable and consistent throughout a routine. My 'conceptual' alternative is the following function (I use the term 'conceptual' as I'm really just demonstrating an alternative idea and the function will only currently process decimal format). [color=GREEN];;------------------------=={ rtos }==------------------------;;[/color] [color=GREEN];; ;;[/color] [color=GREEN];; Subfunction designed to produce a consistent rtos return, ;;[/color] [color=GREEN];; independent of the DIMZIN System Variable. ;;[/color] [color=GREEN];; ;;[/color] [color=GREEN];; [ Currently restricted to Decimal Format only ] ;;[/color] [color=GREEN];;------------------------------------------------------------;;[/color] [color=GREEN];; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;[/color] [color=GREEN];;------------------------------------------------------------;;[/color] [color=GREEN];; Arguments: ;;[/color] [color=GREEN];; real - real number to convert to a string ;;[/color] [color=GREEN];; prec - precision to which the real should be displayed ;;[/color] [color=GREEN];;------------------------------------------------------------;;[/color] [color=GREEN];; Returns: String representing the supplied real ;;[/color] [color=GREEN];;------------------------------------------------------------;;[/color] ([color=BLUE]defun[/color] LM:rtos ( real prec ) ( ([color=BLUE]lambda[/color] ( l ) ([color=BLUE]repeat[/color] ([color=BLUE]-[/color] prec ([color=BLUE]cond[/color] (([color=BLUE]vl-position[/color] 46 l)) (([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] 46 l)) 0))) ([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] 48 l)) ) ([color=BLUE]vl-string-right-trim[/color] [color=MAROON]"."[/color] ([color=BLUE]vl-list->string[/color] ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 46 ([color=BLUE]car[/color] ([color=BLUE]setq[/color] l ([color=BLUE]reverse[/color] l)))) ([color=BLUE]cons[/color] 48 l) ) ( ([color=BLUE]and[/color] ([color=BLUE]=[/color] 45 ([color=BLUE]car[/color] l)) ([color=BLUE]=[/color] 46 ([color=BLUE]cadr[/color] l))) ([color=BLUE]vl-list*[/color] 45 48 ([color=BLUE]cdr[/color] l)) ) ( l ) ) ) ) ) ([color=BLUE]reverse[/color] ([color=BLUE]vl-string->list[/color] ([color=BLUE]rtos[/color] real 2 prec))) ) ) As demonstrated, the return of this function is independent of the value of the DIMZIN System Variable: [color=green]DIMZIN = 0[/color] _$ (LM:rtos 0.234 2) "0.23" [color=green]DIMZIN = 4[/color] _$ (LM:rtos 0.234 2) "0.23" [color=green]DIMZIN = 0[/color] _$ (LM:rtos -0.23 3) "-0.230" [color=green]DIMZIN = 12[/color] _$ (LM:rtos -0.23 3) "-0.230" ================================================== Note that this result differs from Irneb's rtos-dec function for some cases: [color=green]DIMZIN = 4[/color] _$ (LM:rtos 0.234 2) "0.23" _$ (rtos-dec 0.234 2) ".23" [color=green]DIMZIN = 4[/color] _$ (LM:rtos -0.234 2) "-0.23" _$ (rtos-dec -0.234 2) "-.23" ================================================== However, nowadays, I would now be far more inclined to simply use: [color=GREEN];; rtos wrapper - Lee Mac[/color] [color=GREEN];; A wrapper for the rtos function to negate the effect of DIMZIN[/color] ([color=BLUE]defun[/color] LM:rtos ( real units prec [color=BLUE]/[/color] dimzin result ) ([color=BLUE]setq[/color] dimzin ([color=BLUE]getvar[/color] 'dimzin)) ([color=BLUE]setvar[/color] 'dimzin 0) ([color=BLUE]setq[/color] result ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]rtos[/color] ([color=BLUE]list[/color] real units prec))) ([color=BLUE]setvar[/color] 'dimzin dimzin) ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] result)) result ) ) Quote
