MarcooPoloo Posted April 17, 2012 Posted April 17, 2012 Hi everyone, Ive made a tool to cleanup your dwg-drawings: CLEAN UP XREF V1.1 I want to share it, to help each other! Send me your comment! You can download it below. It contains the follow functions: '************************************************************************ '--- SET_UP_DRAWING --- '1 UCS_WORLD '1 PLANVIEW_UCSWORLD '2 SET_UP_VARIABLES '2 SET_UP_UNITS '3 SCALE_DRAWING '4 LTSCALE_ALL_EXCLUDE_BLOCKS (30) 'WAARDE VAN LTSCALE MEEGEVEN '5 LTSCALE_ALL_BLOCKS (15) 'WAARDE VAN LTSCALE MEEGEVEN '6 FLATTEN_DRAWING '--- SET_UP_LAYERS --- '7 STORE_LAYERSTATE '8 RESTORE_LAYERSTATE '9 SET_LAYER_XREF_TEMP_CURRENT '10 ALL_LAYERS_ON '11 UNLOCK_ALL_LAYERS '12 UNFREEZE_ALL_LAYERS '13 LAYERS_LINEWEIGHT_DEFAULT '14 REMOVE_LAYER_FILTERS '--- CLEANING_STUFF --- '15 PURGE_DRAWING '16 AUDIT_MODELSPACE '17 DELETE_LAYOUTS '18 DELETE_VIEWPORTS '19 DELETE_VIEWS '20 DELETE_DIMENSIONS '21 CLEAN_SCALELIST '--- LAYER_STUFF --- '22 CLEAR_LAYER0 ' DELETE_LAYER ("E-61-ELEKTRISCHE BORDEN") 'HIER DIEN JE NAAM VAN LAYER IN TE VULLEN '23 DELETE_FROZEN_LAYERS '24 ALL_BY_LAYER1 '25 ALL_BY_LAYER2 '--- BLOCKS_STUFF --- '26 ALL_BLOCKS_BY_LAYER '27 BURST_EXPLODE_BLOCKS '28 BURST_EXPLODE_DRAWING_DOWN (3) '29 FIX_BLOCK '--- XREF_STUFF --- '30 TRY_TO_RELOAD_ALL_XREFS_UNLOADED '31 TRY_TO_DETACH_ALL_XREFS_UNLOADED '32 BIND_AND_EXPLODE_ALL_XREFS_LOADED '33 DELETE_UNLOADED_IMAGES '--- EXPORT_STUFF --- '34 CREATE_BACKUP_FILE ' SAVE_AS_XREF ' CREATE_WBLOCK '35 COPY_INTO_TEMPLATE '************************************************************************ Help each other to be helped! CLEAN_UP_XREFSv1.1.zipFetching info... Quote
rexxitall Posted April 15, 2015 Posted April 15, 2015 Jos so fix it Usually the 64 systems are just a biot tricky I suggest use at least acad 2014 or better (all 64 versioopns before are *zensored*) then just rewrite the references to the optional calles libs (in 64 bit they need a specuial threadsave flag) Usually it works after that. Quote
