Hi all
Looking for some quick help, I am trying to plot all named views in Model Space via Lisp but im running into a few problems at the moment
the number of views in each drawing varies, i can get the lisp to view each individual view on screen but when printing it only prints the first view multiple times
i.e 8 views total, onscreen it goes to each of the 8 individual views but prints 8 copies of the first view
any ideas?
(defun c:testplot (/ view)
 (while (setq view (tblnext "view" (null
view)))
   (command "_.-view" "_restore" (cdr (assoc 2
view)))
   (command "_.plot" "y" "" "" "A3" "" "" "" "view"
"" "" "" "" "standard.ctb" "" "" "" "y" "")
 ) ;_ while
) ;_ defun
Edited by migs
Instead of "_.view "_restore"
Enter drawing orientation [Portrait/Landscape] <Landscape>: L
Plot upside down? [Yes/No] <No>: N
Enter plot area [Display/Extents/Limits/View/Window] <Window>: [color=blue][b]V[/b][/color]
Enter view name <>: [b][color=blue][supply View Name Here][/color][/b]
I just tried it.. it works here.
                         "view"
                         (null
                               view)))
       [color=blue](command  "_.plot" "Yes"  "Model" "YourPrinter"
             "A3" "Inches" "Landscape"  "No"
             "View" [b](cdr (assoc 2 view))[/b] "Fit"
             "Center" "Yes" "standard.ctb"
             "Yes"  "Wireframe" "No" "No" "Yes")
[/color]        ) ;_ while
Edited by pBe
pBe
i guess my question is:
is there a way to automatically add in the view names rather than specifying each one individually as like i said there could be 3 sheets or 50 sheets on the drawing
thats why i was getting confused as i can get the screen to view each individual sheet automatically but it will only print the first sheet by the number of sheets it finds on screen
Ive never had to deal with this before as id normally use the layout for each sheet however the company has setup the drawings in this way, hopefully i can convince them to change methods but for now im just trying to save some time
pBe
You will need to loop thru tblnext to make a list of "view", i not sure if theres any other way
What you can do is compile the list then print, but that wouldnt be any better that printing while on the loop
[color=blue]"" ;<--- first "view" name will remain as you are accepting the previous view name[/color]
 ) ;_
that is why i suggest passing the view name after "View"
                         "view"
                         (null
                               view)))
[/color]        ) ;_ while
Bingo!
never even thought of adding in (cdr (assoc 2 view)) there :oops:
just running through some checks on it but so far it seems to be exactly what im looking for!
cheers pBe
Good for you. Glad it helps.
BTW: if you want to stick with the way you had it before, use "Display" instead of "view"
