Hi,
Dynamic inputs are a new thing for me and I was wondering if I can change the settings to do the following:-
When DYN is turned on the on screen prompts are shown, this I like but also, if I highlight a pice of geometry and use grips to stretch it goes all a bit wrong. For example, I highlight a rectangle that I want to stretch out by 10mm, grap a grip, push my cursor in the direction I want to go and press 10.....this leads to the total line length being 10mm. This doesn't happen with DYN off, it works how I think it should but obviously without the on screen prompts. Anyway to combine the two?
Thanks
Iain
Do a right-click on DYN button on status bar, chouse Settings... and check if the options available are useful to your case.
Change your dynamic input, pointer input settings to Relative Coordinates instead of Absolute Coordinates. Then your stretch will be relative to the point you start it. It's really early here. I can't seem to open my AutoCad. I hope that works.
Sadly not Dana. It only seems to work as I want it with the DYN button off. Oh well, thanks anyway
is your profile correct? I didn't think 2002 had dynamic input.
DYN settings, Dimension Input >Settings> uncheck Resulting Dimension and check Length Change.
DBroada...no, now using 2007
Rkent....That nearly works, it's closer. I will have a play around and see what I can come up with. It's still not quite there in that if I try to grip stretch a rectangle, for example, one corner will go in the correct axis and the other corner will go in the incorrect axis even though my cursor is going the same way. Hope that makes sense? If I can't figure it out I will just smash my computer and have a little cry. That should help
It sounds like you should turn on ORTHO.
Nope, sadly still no good. Ortho is pretty much always on anyway. I'll go back to my plan of smashing it. Cheers anyway folks :)
Use the Tab key to highlight the parameter you want to alter.
Solved!!! Thank you SLW210. It seems so obvious now.
