cici2012 Posted April 10, 2012 Posted April 10, 2012 I was going through the tutorials for the above topic.Intrying to create the base surface and the create surface dialog box shows up, then I have a problem. After entering the TYPE: Tin Volume Surface. Name:XXXXXX Description:xxxxxxx STYLE: STANDARD This is my problem area. The drop downs do not have Standard in them. What should I do ? Somebody help me pleeeease! Quote
MSasu Posted April 10, 2012 Posted April 10, 2012 Can you clarify please about what command are you talking here? Or, provide the link to the said tutorial - since you are a new user is possible that the post with link will require moderators approval. Quote
JD Mather Posted April 10, 2012 Posted April 10, 2012 Are you using vanilla AutoCAD or are you using Civil 3D? Quote
