I have looked at many of threads, but I did not see the resolution for getting my right mouse button back to normal.
this was in a thread I followed and it summed up what I have best. I use Autocad 2009, I'm a Cad newbee, and I appear to have somehow messed up my right click short-cut menu settings. Before, I could right-click and get all of the edit options (delete, move, rotate, draw order, properties, select similar, etc.). I could get these options whether an object was selected or not. Now, my options are the "default" ones (Repeat, Pan, Zoom, Quick calc, etc, to name a few).
How do you reset the defaults of the mouse buttons?
PS I hate being a beginner.
thanks for your help.:?
Welcome to the forum!
You can fix that in your OPTIONS (right click inside your commandline) > USER PREFERENCES > RIGHT CLICK CUSTOMIZATION.
I like to set mine up so that I can use my right click to either ENTER, or access the SHORTCUT MENUS, so I use the time sensitive right click option. :)
We all started from scratch, don't be disheartened, enjoy the climb.
thanks it worked. I also found under the options option the profile tab it has a reset . It is challenge, but an enjoyable one.:)
  • 1 year later...
I am having the same issue, but changing the settings in the options is NOT helping.
I can no longer select an object, right click and get the modify submenu to display.
any suggestions?
Is your PICKFIRST variable setting set to 1?
It is now.
Thanks that worked.
(I wonder how that got changed)
Glad I could help you. :beer:
Typically a poorly written lisp, aborted mid-execution.
Edited by Dadgad
