I am looking for a way to redefine a mass selection of different blocks to a specified layer and color. They are drawings from another company, so I don't want to explode or take the time to redefine all the blocks to a new layer and color ( most are set to "0" and "white") I've merged layers down to my new layer, but I can't merge 0 to the new layer. Some blocks do have blocks nested inside of them. I don't know if anyone has a LISP that would help.
Thanks
This is a slight alteration of the LISP from my last thread - see if it works for you :)
The layers in the drawing are listed in the "laylist" at the top of the program - you may need to modify this to suit your drawing layer template.
Also, I have set the Layer Colour to "by layer" - this can be changed if need be. :P
; bloclay, created by Lee McDonnell October 2008
(defun c:bloclay (/ laylist ss)
   (setvar "cmdecho" 0)
   (setq laylist '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9")
   ) ; end setq
   (foreach n laylist
       (if
           (setq ss
               (ssget "X"
                   (list
                       (cons 0 "INSERT")
                       (cons 410 (getvar "ctab"))
                       (cons 8 n)
                   ) ; end list
               ) ; end ssget
           ) ; end setq
               (princ "\nType Layer to be moved to: ")
               (command "_.chprop"
                   ss ""
                   "LA"
                   pause
                   "C"
                   "bylayer"
               ) ; end property change
           ) ; end progn
       ) ; end if
   ) ; end foreach
   (setvar "cmdecho" 1)
   (prompt "\nFunction Complete.")
) ; end program
Hope this helps! :)
