Deepdraw Posted March 30, 2012 Posted March 30, 2012 Any Diemaker users on Cadtutor? All of the engineers here at Rockford Toolcraft Inc use AutoCAD 2010 and Diemaker 2010 works within it. AutoCAD is used specifically to design our heavy gauge stamping dies. After some recent upgrades to Windows 7 64bit PCs, Diemaker refuses to install correctly on two of them. There is no error message, it simply does not show up within AutoCAD. There is usually a toolbar. It runs perfectly on the others. All of the PCs are alike. Helpful ideas would be greatly appreciated. Quote
ReMark Posted March 30, 2012 Posted March 30, 2012 Some programs refuse, for whatever reason, to install under Win7 64-bit. Have you contacted Diemaker support to inquire about the problem? Quote
Deepdraw Posted March 30, 2012 Author Posted March 30, 2012 Thank you for your reply. Yea, it's seems hit and miss. It just refuses to install on two, but the rest it works perfectly. Yes, the support guru has been in a couple of times and with no luck. Quote
ReMark Posted March 30, 2012 Posted March 30, 2012 It shouldn't be. Do all the computers share the same configuration? If not, what are the differences? Quote
Deepdraw Posted March 30, 2012 Author Posted March 30, 2012 Yes, they are all the same configuration. No differences whatsoever. Quote
ReMark Posted March 30, 2012 Posted March 30, 2012 Did IT try disabling the antivirus program during the install process? When the install did not work were there any error messages? Quote
rkent Posted March 30, 2012 Posted March 30, 2012 I would go to one of the machines where the install worked, open AutoCAD, go to Options, Files, Support File Search Path, make a copy of all the paths there. Then go to one where it won't open and compare the file path to the good machine. If something is missing add it into the one missing it. Open a drawing and try again. I would also start AutoCAD making sure to use a new profile and maybe do that while logged in as Admin to eliminate any problems with profiles as a cause. Quote
Deepdraw Posted March 30, 2012 Author Posted March 30, 2012 Yes, anitivirus was uninstalled prior to the Diemaker install. There was no error message. Thanks again. Quote
Deepdraw Posted March 30, 2012 Author Posted March 30, 2012 (edited) I would go to one of the machines where the install worked, open AutoCAD, go to Options, Files, Support File Search Path, make a copy of all the paths there. Then go to one where it won't open and compare the file path to the good machine. If something is missing add it into the one missing it. Open a drawing and try again. I would also start AutoCAD making sure to use a new profile and maybe do that while logged in as Admin to eliminate any problems with profiles as a cause. Just looked into this. The folders match and both show the software is there. The software does run as local Administrator, but refuses to run as an Administrator on the domain. Again, only two PCs do this, the others run perfectly on the domain. Thank you for the insight. Edited March 30, 2012 by Deepdraw Quote
ReMark Posted March 30, 2012 Posted March 30, 2012 Ah...another piece of the puzzle has been provided. Quote
AlienBZ Posted October 27, 2012 Posted October 27, 2012 Just looked into this. The folders match and both show the software is there. The software does run as local Administrator, but refuses to run as an Administrator on the domain. Again, only two PCs do this, the others run perfectly on the domain. Just my half-cent's worth of thought: Perhaps the software runs perfectly as local admin whereas it does not run as domain admin by any chance? - again, this is just a thought. Quote
