Hi,
Does anyone now away of altering the drawing properties without opening the drawing?
I have set up a few custom properties and linked them to fields in my title block.
I was hoping to be able to update the title blocks drawing status without opeing the drawing in this manner.
I have tried it and it works fine modify the drawing properties within the drawing but when i try to do this without opening the drawing the properties are locked?
Thanks for any help,
col.
I haven't found a way to do change the custom properties externally. I did write a script or VBA routine (can't remember which) to change a batch of drawings but each drawing still needed openning.
Yeah I spent ages last night googling trying to find out if its possible and couldnt get one example.
I will have a look at vba, it would have been so much easier if the propeties were editable externally!
thanks for the confirmation.
Cheers,
col
