pete1968 Posted March 28, 2012 Posted March 28, 2012 how to create a sketch plane parallel with bottom of pie section of floor SKETCH PLANE.ipt Quote
pete1968 Posted March 28, 2012 Author Posted March 28, 2012 this is the profile of sktech i want extrude centered in one of the pie sections SKETCH PLANE.ipt Quote
JD Mather Posted March 28, 2012 Posted March 28, 2012 Not sure I understand what you mean - but you should be able to create any workplane you want. But Workplanes 1 and especially 2 & 3 are not needed - use the origin workplanes as a more robust method of modeling. You did duplicate work. Sketch 4 is unconstrained and looks like AutoCAD work? Looks like problems with Sketches 5, 7, 8 & 9 as well and I suspect extra work but I quit looking. See if attached image helps. Quote
JD Mather Posted March 28, 2012 Posted March 28, 2012 Now that I see the second file - that is even easier. Hollar back if you can't figure it out from the image I posted. Quote
pete1968 Posted March 28, 2012 Author Posted March 28, 2012 Thanks for looking at the file. I see from your your image that you have the orgin workplane highlighted then a sketch plane in orange whick looks parallel to the bottom floor.So how did you create that. Quote
pete1968 Posted March 28, 2012 Author Posted March 28, 2012 This is what i figured out I uses sketch geo from the revolved feature to align my work plane SKETCH PLANE.ipt Quote
