comcu Posted October 26, 2008 Posted October 26, 2008 Hi, Has anyone loaded a access data base into a data grid on a acad vba form? I have done this with vb6 before and tried to replicte the same with acad but the data grid seems to be missing the 'datasource' propertie? I have loaded the datagrid and adodc control and set the connection string and the control sourc but like i said the datagrid does not have a 'datasource' propertie? Cheers for any help, Col. Quote
borgunit Posted October 28, 2008 Posted October 28, 2008 I believe you would set that at runtime and not on the form. Here is an example I found.. strSQL = "SELECT NameLast, NameFirst, SomeMoney " & _ " FROM tblMyTable_0 M0, MyTable_3 M3 " & _ " WHERE M0.sysid = M3.sysid " & _ " ORDER BY NameLast " rs.Open strSQL) With dGrid Set .DataSource = rs .Visible = True .Top = TopPosition .Left = LeftPosition .Height = HeightValue .Width = WidthValue .AllowArrows = True .AllowRowSizing = True .ColumnHeaders = True For intRefCol = lBound(arrCol) To uBound(arrCol) With .Columns(intRefCol) .Button = True .Width = arrRefDisplayColWidth(intRefCol) .Caption = arrRefDisplayHeading(intRefCol) k = arrRefFieldSeq(intRefCol) Select Case arrRefFieldXref(k) Case "SomeMoney" .Alignment = dbgRight .NumberFormat = "$#,###.00" Case else .Alignment = dbgLeft End Select End With Next blnSortAsc = False .Refresh End With Quote
comcu Posted October 28, 2008 Author Posted October 28, 2008 Thank you for that, i will have a play around with the code. Cheers, Col Quote
