justin.grant Posted July 28, 2022 Share Posted July 28, 2022 test.dwgIn the example attatched I want to take the Green polyline square footage, and subtract the magenta polyline square footage. There are always just one 'green' polyline, but there could be one, or multiple, 'magenta' polylines. I then need that number, in square feet, to populate the RMAREA portion of the attribute attached to the Usable Square Footage block. Thank you for looking at this. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 28, 2022 Share Posted July 28, 2022 (edited) Took me like 10 seconds to get answer. You isolate the layers green and magenta, then do a bpoly. Pick inside, just did a List and picked the outer new PLINE Green = 479812 Inside Green = 462049 I did something recently where I just got all the new bpoly's and compared the area so largest is answer. So it can be semi automated. Do you have magenta plines inside ? If so could do a pick subtract object. I will try to find again may have been here I don't save every lisp I do as have thousands. Edited July 28, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
ronjonp Posted July 29, 2022 Share Posted July 29, 2022 Not using code, turn the objects into regions then subtract the small areas from the large one. Quote Link to comment Share on other sites More sharing options...
justin.grant Posted July 29, 2022 Share Posted July 29, 2022 Thank you BIGAL and ronjonp, but this isn't quite what I need. I'd like the total square footage, Green - Magenta, and have the total saved in the attribute of the block that I select. Lee Mac posted one 4 years ago that almost gets me there, , but it would only adds polylines and doesn't give an option to subtract. Quote Link to comment Share on other sites More sharing options...
mhupp Posted July 29, 2022 Share Posted July 29, 2022 Will have to make some edits but this should get you going. https://www.theswamp.org/index.php?topic=53534.msg582412#msg582412 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 30, 2022 Share Posted July 30, 2022 (edited) That was what I proposed the code that I posted somewhere works out the area of the new Bpoly's and compares them to work out largest, so then just put area into a block attribute, again I will try to find, it was not that long ago. Start searching BIGAL area lisp autocad. Edited July 30, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
justin.grant Posted August 10, 2022 Share Posted August 10, 2022 Thank you mhupp and BIGAL. I'm still unable to figure out a solution. I'm not a LISP coder, so I can't get it right A quick recap, I have a single polyline around the exterior of a building floor, and multiple polylines inside that polyline, representing stairs, restrooms, additional core space, that I want excluded from the exterior area. Example is in my post from above. As stated above, Lee Mac almost gets me there, I just need the option to remove interior polyline areas from the exterior polyline area. Thanks again for the help. Quote Link to comment Share on other sites More sharing options...
justin.grant Posted August 10, 2022 Share Posted August 10, 2022 Also pBe's lisp from above works great. If it could put the total area, in sq ft, in an existing attribute, that would also work. Quote Link to comment Share on other sites More sharing options...
