glazier Posted March 17, 2012 Posted March 17, 2012 Is there a way to permanently save dim and text styles in autocad without going to another drawing template and loading it or putting it in the default drawing template. is there a place add and to store the dimension and text to a dim dex file so it always opens up in autocad. Quote
tzframpton Posted March 17, 2012 Posted March 17, 2012 Sure, start utilizing the Tool Palettes. What you do is round up all your Dimensions and create a Block of them all. Save the DWG file somewhere in a location that you can always access, then Drag/Drop them into a new Tool Palette. Anytime you open a new drawing, just plop in the block and delete it, and all your DIM styles will carry over with it. Attached is an example of mine.... **EDIT** Here is some extra info on Tool Palettes in case you are new to them. They are highly versatile and can help in so many ways if you give them a chance. http://exchange.autodesk.com/autocad/enu/online-help/search#WS73099cc142f48755-1257e12111bf108800e-10a.htm LAN - Annotations & Styles.dwg Quote
ReMark Posted March 17, 2012 Posted March 17, 2012 You can always drag and drop the styles into any drawing you're working in via the Design Center too but working off a tool palette is probably a lot easier. Quote
nestly Posted March 17, 2012 Posted March 17, 2012 For a more automatic approach, I believe you could have acaddoc.lsp perform the suggestions above each time a drawing is opened. Quote
BIGAL Posted March 23, 2012 Posted March 23, 2012 A little bit harder you could do a lisp say pick from a dialouge what one you want and create it then in current drawing. Quote
