Tharwat Posted June 24, 2014 Share Posted June 24, 2014 Try this simple routine and pay your attention to the command line at the end of the program , you should see a list of the values . (defun c:Test (/ o f str p lst) (if (and (setq o (getfiled "" (getvar 'dwgprefix) "csv" 16)) (setq f (open o "r")) ) (progn (while (setq str (read-line f)) (if (setq p (vl-string-search "," str 0)) (setq lst (cons (substr str 1 p) lst)) ) ) (close f) ) ) (if lst (setq lst (reverse lst)) ) ) Quote Link to comment Share on other sites More sharing options...
jmerch Posted June 24, 2014 Share Posted June 24, 2014 ("Number" "1" "2" "3" "4" "5" "6") so...for each 'lst', I need to perform my commands....am I thinking right? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 24, 2014 Share Posted June 24, 2014 ("Number" "1" "2" "3" "4" "5" "6") Good , is not that what you've looking for since your first question in this thread ? so...for each 'lst', I need to perform my commands....am I thinking right? Correct , but it also depends on what you are trying to do with the list ? Quote Link to comment Share on other sites More sharing options...
jmerch Posted June 24, 2014 Share Posted June 24, 2014 Yes that is what I was looking for, my initial thought was to populate this list in order to separate it out. Then the more I got into it, I liked the idea of skipping that step and just having the LISP execute my commands 'foreach' number in the list, keeping that 'setq' definition saved so I can use it in my filter. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 24, 2014 Share Posted June 24, 2014 Then the more I got into it, I liked the idea of skipping that step and just having the LISP execute my commands 'foreach' number in the list, keeping that 'setq' definition saved so I can use it in my filter. Just ask if you stuck with any of your process with LISP and not with your third party commands . Quote Link to comment Share on other sites More sharing options...
