MR MAN Posted October 25, 2008 Posted October 25, 2008 Is There Any Way To Make Circle As Polyline So I Can Make It With Width I Need? Quote
tzframpton Posted October 25, 2008 Posted October 25, 2008 Don't do that... just start the POLYLINE command, then type A for Arc. when you do that, you can create a circle by simply using your POLAR tracking to make two "arcs". The width should be self explanatory after that. Quote
eldon Posted October 25, 2008 Posted October 25, 2008 Or go for a Donut, which is a polyline circle with width 1 Quote
profcad Posted October 26, 2008 Posted October 26, 2008 Use the BOUNDARY command and pick a point inside the circle. AutoCAD will create a polyline on top of the circle. Quote
BOB'27T Posted October 26, 2008 Posted October 26, 2008 Here's another option Adding global width to a circle Here's a little trick I learned a while back. I needed to add thickness to a circle & found a slick way to do it. Here goes: Start by making a polygon with 4 sides. Check inscribed in circle when prompted. Next specify your radius. That will create a square. Then select polyline edit, then select fit, then width. Tah Dah! You have a circle with a global width! Quote
mugshot Posted October 28, 2008 Posted October 28, 2008 start w/ polyline, set width. w ( upon your choice) then arc. Quote
mugshot Posted October 28, 2008 Posted October 28, 2008 or make a polyline that is set upon a width then matchprop the line to your created circle. Quote
bonehead411 Posted October 28, 2008 Posted October 28, 2008 Use the BOUNDARY command and pick a point inside the circle. AutoCAD will create a polyline on top of the circle. Oh now that's a beauty! Cheers prof. Quote
270 Posted September 25, 2018 Posted September 25, 2018 I agree with Bonehead, I prefer the method that profcad offered. Thanks profcad. Quote
BIGAL Posted September 27, 2018 Posted September 27, 2018 If you did a bit of searching here you would have found a circle with a width and a smart offset. circle - donut.lsp getval2.lsp Quote
rkent Posted September 27, 2018 Posted September 27, 2018 I use one by Jason Piercey ;Written By: Jason Piercey 07.31.01 ;Revised: 01.16.02 To handle multiple selection (defun C:Circle2Pline (/ CirEnt CirElst CirCen CirRad CirLay CirLin CirClr CirLts PlineEnt ss i) (setq ss (ssget '((0 . "CIRCLE")))) (if ss (progn (setq i 0) (repeat (sslength ss) (setq CirEnt (ssname ss i) CirElst (entget CirEnt) CirCen (cdr (assoc 10 CirElst)) CirRad (cdr (assoc 40 CirElst)) CirLay (cdr (assoc 8 CirElst)) CirLin (cdr (assoc 6 CirElst)) CirClr (cdr (assoc 62 CirElst)) CirLts (cdr (assoc 48 CirElst)) ) (setq PlineEnt (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") (cons 8 CirLay) '(100 . "AcDbPolyline") '(90 . 2) '(70 . 1) '(43 . 0.0) '(38 . 0.0) '(39 . 0.0) (cons 10 (polar CirCen (* pi) CirRad)) '(40 . 0.0) '(41 . 0.0) '(42 . 1.0) (cons 10 (polar CirCen (* pi 2.0) CirRad)) '(40 . 0.0) '(41 . 0.0) '(42 . 1.0) '(210 0.0 0.0 1.0) ) ) (if CirLin (setq PlineEnt (append PlineEnt (list (cons 6 CirLin))))) (if CirClr (setq PlineEnt (append PlineEnt (list (cons 62 CirClr))))) (if CirLts (setq PlineEnt (append PlineEnt (list (cons 48 CirLts))))) (entmake PlineEnt) (entdel CirEnt) (setq i (1+ i)) ) ) ) (princ (strcat "\n"(itoa i) " Circles converted to LwPolylines")) (princ) ) Circle2Pline.lsp Quote
rkmcswain Posted September 27, 2018 Posted September 27, 2018 I did not see this listed, but another alternative would be to draw a polygon with a lot (say 500?) sides. It won't be a true arc or circle obviously, but there may be a case where you need line segments that look like a circle (example: XCLIP) Quote
