justmeagain Posted March 13, 2012 Posted March 13, 2012 Hello, I am developing a 3D project, using Autocad. The project includes a sink (American Standard) and is available only in *.rfa format and I don't have Revit Please, is it possible for anyone to convert this file to DWG ? Thank you in advance!! 44E54778.rfa Quote
RobDraw Posted March 13, 2012 Posted March 13, 2012 I don't think that it is possible to convert it to a 3D object. As far as I know you can only export 2D views to .dwg from Revit. Quote
justmeagain Posted March 13, 2012 Author Posted March 13, 2012 I don't think that it is possible to convert it to a 3D object. As far as I know you can only export 2D views to .dwg from Revit. According with the info I saw, the file can be exported to DWG http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Convert-RFA-to-DWG-or-DXF/td-p/2766470 Please? Thank you, Pat Quote
RobDraw Posted March 13, 2012 Posted March 13, 2012 Please look at the .dwgs that were provided. They are in 2D! You requested 3D! Quote
justmeagain Posted March 13, 2012 Author Posted March 13, 2012 Thank you for your answer I know that the example shows 2D, I just intended to show an example. I remember when I did a Revit Wokshop, we were told this concept, exactly http://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/133/message-id/4539/print-single-message/true/page/1 Quote
Lee Roy Posted March 13, 2012 Posted March 13, 2012 Give me a couple minutes. -Edit- Attached are both an ACIS and a Polymesh version of the supplied .rfa family. The attached files are ACAD 2007 format. If you need anything else, please don't hesitate to ask. @RobDraw - Converting Revit files (of any type) is insanely easy. It took me longer to type this response than it took me to convert the supplied .rfa family into both of the attached files. Sink-Polymesh.dwg Sink-ACIS.dwg Quote
justmeagain Posted March 13, 2012 Author Posted March 13, 2012 Lee Roy, Thank you so much!!!!!! Pat Quote
Lee Roy Posted March 13, 2012 Posted March 13, 2012 You're welcome. ...and welcome to CADTutor! Kick back, relax and stay a while. Quote
