help.. how do i remesh the t-spline meshes without making it curvy?
yacy
hello
i was wondering if someone would help me out a little with t-spline?
i have used t-spline simply to edit the edge faces of the geometry im currently working on, which is not meant to be very curvy at all...
but once i have converted the meshed surfaces to t-spline, it seems impossible to convert it back without adding curvatures to the surface.
im simply after the geometry that is shown when the smooth toggle is off...
is there a way to export the geometry without altering its surface curvature?
