ReMark Posted March 9, 2012 Posted March 9, 2012 CADTutor....a group "think tank" for CAD. That's us! Good thing you weren't looking to do it in Kodachrome! Glad to hear you got it all sorted out and thanks for updating us. Quote
MSasu Posted March 9, 2012 Posted March 9, 2012 Good to hear that you got it solved! One suggestion, do not alter the configurations that come with AutoCAD (CTB files, linetype files and other); instead create your own versions. This way will ensure compatibility when share the drawings with someone else and can port your settings to other workstations or AutoCAD versions. Regards, Mircea Quote
k_udhay Posted March 9, 2012 Author Posted March 9, 2012 msasu said: Good to hear that you got it solved! One suggestion, do not alter the configurations that come with AutoCAD (CTB files, linetype files and other); instead create your own versions. This way will ensure compatibility when share the drawings with someone else and can port your settings to other workstations or AutoCAD versions. Regards, Mircea Yeah sure... Thanks... Quote
rkent Posted March 9, 2012 Posted March 9, 2012 FYI - if you encounter a file using STB, any layer or object set to Plot Style 'normal' means that object or layer will plot according to its color. For this example if you had changed the layer to Style 1 then it would have plotted monochrome. Quote
