asos2000 Posted March 6, 2012 Posted March 6, 2012 Could some one help me plz - get a point - Select first text to move to new location - Select second text to move to new location Thanks Edit: To be repeated. its huge plan Quote
MSasu Posted March 6, 2012 Posted March 6, 2012 One solution: (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (car (entsel)) label2nd (car (entsel)))) (progn (foreach moveSet (list (list label1st 300.0 0.0) (list label2nd 300.0 400.0)) (setq entList (entget (car moveSet))) (entmod (subst (list '10 (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Quote
asos2000 Posted March 6, 2012 Author Posted March 6, 2012 One solution: ... Regards, Mircea Great Thanks To repeated using WHILE and working fine (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (if (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (car (entsel)) label2nd (car (entsel)))) (progn (foreach moveSet (list (list label1st 300.0 0.0) (list label2nd 300.0 400.0)) (setq entList (entget (car moveSet))) (entmod (subst (list '10 (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) (assoc 10 entList) entList)) ) ) ) ) (princ) ) Quote
MSasu Posted March 6, 2012 Posted March 6, 2012 You’re welcome! Have noticed late the repeat request - you can check the revised version. However, your change is OK too. Regards, Mircea Quote
asos2000 Posted March 6, 2012 Author Posted March 6, 2012 You’re welcome!... Regards, Mircea tried to avoid UCs change But not worked (defun C:Mll ( / thePoint label1st label2nd moveSet entList) (while t (if (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (car (entsel)) label2nd (car (entsel)))) (progn (setq thePoint (trans thePoint 1 0)) (foreach moveSet (list (list label1st 300.0 0.0) (list label2nd 300.0 400.0)) (setq entList (entget (car moveSet))) (entmod (subst (list '10 (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) (assoc 10 entList) entList)) ) ) ) ) (princ) ) Quote
MSasu Posted March 6, 2012 Posted March 6, 2012 Should transpose the point after calculate displacement (presuming that the UCS is aligned with reference): (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (car (entsel)) label2nd (car (entsel)))) (progn (foreach moveSet (list (list label1st 300.0 0.0) (list label2nd 300.0 400.0)) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Quote
asos2000 Posted March 6, 2012 Author Posted March 6, 2012 Should transpose... Regards, Mircea Thanks Mircea Quote
MSasu Posted March 6, 2012 Posted March 6, 2012 Just play with the values that I have colored in red (X), blue (Y1) and green (Y2) to match your case. (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (car (entsel)) label2nd (car (entsel)))) (progn (foreach moveSet (list (list label1st [color=red]300.0[/color] [color=blue]-100.0[/color]) (list label2nd [color=blue][color=red]300.0[/color][/color] [color=green]-400.0[/color])) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Quote
antistar Posted March 6, 2012 Posted March 6, 2012 Just play with the values that I have colored in red (X), blue (Y1) and green (Y2) to match your case. (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (car (entsel)) label2nd (car (entsel)))) (progn (foreach moveSet (list (list label1st [color=red]300.0[/color] [color=blue]-100.0[/color]) (list label2nd [color=blue][color=red]300.0[/color][/color] [color=green]-400.0[/color])) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Excuse me Mircea, I believe that I was not very clear earlier. Do not want to select the point, but the POLYLINE. And that texts are always located from the lower right corner of the polyline. Quote
asos2000 Posted March 6, 2012 Author Posted March 6, 2012 Just pick the lower-right corner The same answer Just pick the point Quote
antistar Posted March 28, 2012 Posted March 28, 2012 Thanks Mircea Hi to all, This routine is very helpful to me. I have a question: How to filter selection "label1st" only if the object is on layer XXX, and the selection of "label2nd" only if the object is on layer YYY? Thanks in advance. Quote
MSasu Posted March 28, 2012 Posted March 28, 2012 Thanks for the comments. To filter the labels by specific layers, just modify the code below with you layer names: (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (ssget "_:S:E" '((0 . "TEXT") (8 . "[color=magenta]XXX[/color]")))) (setq label2nd (ssget "_:S:E" '((0 . "TEXT") (8 . "[color=magenta]YYY[/color]"))))) (progn (setq label1st (ssname label1st 0) label2nd (ssname label2nd 0)) (foreach moveSet (list (list label1st 300.0 0.0) (list label2nd 300.0 400.0)) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Quote
antistar Posted March 28, 2012 Posted March 28, 2012 Thanks for the comments. To filter the labels by specific layers, just modify the code below with you layer names: (defun C:MoveLabels( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nInsertion point: ")) (setq label1st (ssget "_:S:E" '((0 . "TEXT") (8 . "[color=magenta]XXX[/color]")))) (setq label2nd (ssget "_:S:E" '((0 . "TEXT") (8 . "[color=magenta]YYY[/color]"))))) (progn (setq label1st (ssname label1st 0) label2nd (ssname label2nd 0)) (foreach moveSet (list (list label1st 300.0 0.0) (list label2nd 300.0 400.0)) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Mircea, thanks for your reply. I understood the logic of its modification, but is returning the following error: Command: MoveLabels nInsertion point: Select objects: Select objects: ERROR: bad argument type: lentityp <Selection set: 151> Command: Quote
MSasu Posted March 28, 2012 Posted March 28, 2012 Can you post please how you changed the code from post #13 to suit your case? Regards, Mircea Quote
antistar Posted March 28, 2012 Posted March 28, 2012 Can you post please how you changed the code from post #13 to suit your case? Regards, Mircea This is my changed code: (defun c:ML ( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nPoint: ")) (setq label1st (ssget "_:S:E" '((0 . "TEXT") (8 . "LAYER1")))) (setq label2nd (ssget "_:S:E" '((0 . "TEXT") (8 . "LAYER2"))))) (progn (foreach moveSet (list (list label1st 10.0 -25.0) (list label2nd 10.0 -42.0)) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Quote
MSasu Posted March 28, 2012 Posted March 28, 2012 Im afraid that you forgot to copy some lines: (defun c:ML ( / thePoint label1st label2nd moveSet entList) (while (and (setq thePoint (getpoint "\nPoint: ")) (setq label1st (ssget "_:S:E" '((0 . "TEXT") (8 . "LAYER1")))) (setq label2nd (ssget "_:S:E" '((0 . "TEXT") (8 . "LAYER2"))))) (progn [color=red] (setq label1st (ssname label1st 0) label2nd (ssname label2nd 0))[/color] (foreach moveSet (list (list label1st 10.0 -25.0) (list label2nd 10.0 -42.0)) (setq entList (entget (car moveSet))) (entmod (subst (cons '10 (trans (list (+ (car thePoint) (cadr moveSet)) (+ (cadr thePoint) (caddr moveSet)) (caddr thePoint)) 1 0)) (assoc 10 entList) entList)) ) ) ) (princ) ) Regards, Mircea Quote
