I need to create a "pline arc"(Arc option in PLine) and connect a set of blocks.
So i m developing a lisp to do it.
1. I get the objects from user using "ssget"
2. I am using COMMAND command to draw PLine arc option to draw pline between the blocks's POSITION property
3. but the COMMAND command has to be closed using [ '') ]
4. But i need to give the next argument iteratively using for loop
5. How to iteratively give the next arguments in COMMAND command
THANKS in ADVANCE
To draw a polyline with a list of points:
(command "_PLINE")   ;start command
(foreach thePoint MyPointsList
(command thePoint)
(command "")   ;close command
Regards,
Mircea
(setq pointlist (list '(0 0 0)'(10 10 0)'(5 15 0)'(20 5 0)))
(command "_.PLINE")
(apply 'command pointlist)
(command "")
