How to Draw Slab Symbol by one click ????
Hope this would help you with it .
(defun c:TesT (/ p1 p2 p3 p4 cntr)
;;; Tharwat 06. March 2012 ;;;
;;;    Draw Slab Symbol    ;;;
 (defun CrossLine (a b)
   (entmake
     (list '(0 . "LINE")
           (cons 10 a)
           (cons 11
                 (polar a (angle a b) (- (/ (distance a b) 2.) 0.225))
           (cons 8 "_layer S-SPEC-SLAB")
 (defun _Text (p str)
   (entmake (list '(0 . "TEXT")
                  '(40 . 0.2)
                  (cons 1 str)
                  (cons 10 p)
                  (cons 11 p)
                  (cons 7 (getvar 'textstyle))
                  '(51 . 0.)
                  (cons 8 "_layer S-SPEC-TEXT")
                  '(71 . 0)
                  '(72 . 1)
                  '(73 . 2)
                  '(210 0.0 0.0 1.0)
 (if (and
       (setq p1 (getpoint "\n First corner :"))
       (setq p2 (getcorner p1 "\n Second corner :"))
     (setq p3 (list (car p1) (cadr p2) 0.)
           p4 (list (car p2) (cadr p1) 0.)
     (if (> (distance p1 p3) 1.5)
         (setq
           cntr (mapcar
                  (function
                    (lambda (first second) (/ (+ first second) 2.))
                  p1
                  p2
         (CrossLine p1 p2)
         (CrossLine p2 p1)
         (CrossLine p3 p4)
         (CrossLine p4 p3)
         (entmake (list '(0 . "CIRCLE")
                        (cons 10 cntr)
                        '(40 . 0.225)
         (_Text cntr "GS")
         (_Text (polar cntr 4.71239 0.4) "+0.20")
       (princ
         "\n *** Diameter of Rectangle is too small must be minimum 1.50 *** "
  • Replies 22
  • git_thailand
    8
  • Tharwat
    4
  • ReMark
    3
  • asos2000
    2
Posted Images
   (entmake
     (list '(0 . "LINE")
           (cons 10 a)
           (cons 11
                  '(40 . 0.2)
                  (cons 1 str)
                  (cons 10 p)
                  (cons 11 p)
                  '(51 . 0.)
                  '(71 . 0)
                  '(72 . 1)
                  '(73 . 2)
                  '(210 0.0 0.0 1.0)
 (if (and
         (setq
           cntr (mapcar
                  (function
                  p1
                  p2
         (CrossLine p1 p2)
         (CrossLine p2 p1)
         (CrossLine p3 p4)
         (CrossLine p4 p3)
                        (cons 10 cntr)
                        '(40 . 0.225)
         (_Text cntr "GS")
       (princ
thank you. How to add function change text and loop
Things like this ..... ?
(defun c:TesT (/ p1 p2 str p3 p4 cntr)
;;; Tharwat 07. March 2012 ;;;
   (entmake
     (list '(0 . "LINE")
           (cons 10 a)
           (cons 11
                  '(40 . 0.2)
                  (cons 1 str)
                  (cons 10 p)
                  (cons 11 p)
                  '(51 . 0.)
                  '(71 . 0)
                  '(72 . 1)
                  '(73 . 2)
                  '(210 0.0 0.0 1.0)
 (while
   (and
     (not (eq (setq str (getstring t "\n Enter text :")) ""))
          (setq
            cntr (mapcar
                   (function
                   p1
                   p2
          (CrossLine p1 p2)
          (CrossLine p2 p1)
          (CrossLine p3 p4)
          (CrossLine p4 p3)
                         (cons 10 cntr)
                         '(40 . 0.225)
          (_Text cntr str)
        (princ
