svorgodne Posted March 1, 2012 Share Posted March 1, 2012 Is there anybody who can tell me where can I find information about ALL VLA-... COMMANDS. It's a disaster not to be able to find any information on the help of AutoCAD 2006 and some others about it. Normally it would be possible to run a routine, script, lisp or whatever within AutoCAD and get a result, but it is really an act of faith not to find a-n-y information about it on the help from the program. I would like to know what it's possible and not to do through a lisp routine. Thanks in advance Quote Link to comment Share on other sites More sharing options...
fixo Posted March 1, 2012 Share Posted March 1, 2012 I recommend: www.afralisp.net http://www.google.ru/search?ie=UTF-8&hl=ru&q=The%20Visual%20LISP%20Developer%27s%20Bible%202003 ~'J'~ Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 1, 2012 Share Posted March 1, 2012 Use the ActiveX & VBA Reference in the Visual LISP IDE (VLIDE) Help Documentation. It contains all the properties & methods of the AutoCAD Object Model; all other Visual LISP funcitons (vl-* / vlr-* / vlax-*) are contained in the standard AutoLISP Reference. The ActiveX & VBA Reference is written for VBA, but the translation to LISP is obvious since the number of parameters / data types / parameter order are all the same. If you're running a version of AutoCAD pre 2011, the ActiveX & VBA Reference (acadauto.chm) file is directly linked to the VLIDE Help button. If you're running a version of AutoCAD 2011 onwards, the acadauto.chm file can still be found at: C:\Program Files\Common Files\Autodesk Shared Quote Link to comment Share on other sites More sharing options...
svorgodne Posted March 1, 2012 Author Share Posted March 1, 2012 Thank you both. At least I have a guideline to keep searching Quote Link to comment Share on other sites More sharing options...
