Hi All,
I'm looking for a routine that when i select the text it would create a layer with the text as it's name. i.e text (S7) = layer name is S7.
thanks
Brian
Good time to learn lisp no code but
1 use entsel to pick text then using Assoc you can get the text value
2 command layer N textvalue etc
Look up help the 1st item is the basis of heaps of lisps just search through a few of the posts
