K-Ro0 Posted October 23, 2008 Posted October 23, 2008 Ok, here I am again. I can't find the setting that keeps my paperspace and model space at the same scale when I use the tab. I am trying to move the drawing through my viewport but not change the scale of the drawing. When I am in the layout tab and I click the model space tab it zooms extents and I do not want that to happen. I have tried the UCSFOLLOW command, but the default is already 0. Please help again. Thanks from the frustrated Ro0. I am using Autocad 2009 LT Quote
hazardman Posted October 23, 2008 Posted October 23, 2008 ucsfollow is the correct way to go...what you need to keep in mind is that it's value can be set independantly in each unlocked viewport, model space, and paperspace so you will need to make sure they're all set to zero in the various "spaces"... Quote
K-Ro0 Posted October 23, 2008 Author Posted October 23, 2008 Thanks hazzardman. I got it fixed. I don't know how but after I posted the darn thing worked. Buggy i guess. Or maybe it's the loose nut behind the keyboard! Quote
