Number Array Difficulties - Probably Just a Simple Mistake...
Hi Guys,
I have just been creating a LISP to produce a number array, but can't get it to work.
I would appreciate it if someone could point out the mistake in my program :)
(defun c:numarray (/ snum enum incr txpt cnt ldir lspc)
   (while
       (and
           (setq snum (getreal "\nSpecify Starting Number: "))
           (setq enum (getreal "\nSpecify Ending Number: "))
           (setq incr (getreal "\nSpecify Increment Size [> 0.01]: "))
           (setq txpt (getpoint "\nSelect First Text Base Point: "))
       ) ; end and
       (setq cnt snum)
       (initget 1 "Up" "Down" "Left" "Right")
       (setq ldir (getkword "\nSpecify List Direction (Up/Down/Left/Right): "))
       (setq lspc (getreal (strcat "Specify List Spacing [>"
                       (rtos (* 2.5 (getvar "DIMSCALE")) 2 2)
                   ) ; end strcat
              ) ; end getreal
       ) ; end setq
       (while
           (<= cnt enum)
           (entmake    (list    '(0 . "TEXT")
                       '(8 . "TEXT")
                       (cons 10 txpt)
                       (cons 40 (* 2.5 (getvar "DIMSCALE")))
                       (cons 1 (rtos cnt 2 2))
                       (cons 50 0.0)
                       '(7 . "STANDARD")
                       '(71 . 0)
                       '(72 . 1)
                       '(73 . 2)
                       (cons 11 txpt)
                   ) ; end list
           ) ; end entmake
           (setq cnt (+ cnt incr))
           (cond
               ((= ldir "Up")
               (setq txpt (list (car txpt)(+ (cadr txpt) lspc)(caddr txpt)))
               ) ; end cond 1
               ((= ldir "Down")
               (setq txpt (list (car txpt)(- (cadr txpt) lspc)(caddr txpt)))
               ) ; end cond 2
               ((= ldir "Right")
               (setq txpt (list (+ (car txpt) lspc)(cadr txpt)(caddr txpt)))
               ) ; end cond 3
               ((= ldir "Left")
               (setq txpt (list (- (car txpt) lspc)(cadr txpt)(caddr txpt)))
               ) ; end cond 4
           ) ; end cond
       ) ; end while
   ) ; end while
   (prompt "\nFunction Complete.")
) ; end program
Thanks in advance for any help given :)
Right off the bat I noticed that your initget has too many arguments
should be
(initget 1 "Up Down Left Right")
Excellent, thanks for that lpseifert - I knew it would be something as simple as that... :P
Hi Guys,
Once again, thanks for your help with my LISP program :D
Now that I have finished it, I thought I might upload it so that if it is of any use to anyone to help speed up their work, they are free to use it or modify it to better suit their needs. :)
So here it is:
(defun c:numarray (/ pref ptxt snum enum incr txpt cnt ldir lspc)
   (initget "Yes No")
   (setq pref (getkword "\nPrefix Text? [Yes/No]: "))
   (if (= pref "Yes")
       (setq ptxt (getstring t "\nSpecify Prefix: "))
   ) ; end if
   (while
       (and
       ) ; end and
       (setq cnt snum)
       (setq lspc (getreal (strcat "\nSpecify List Spacing [> "
                       (rtos (getvar "TEXTSIZE") 2 2)
                   ) ; end strcat
              ) ; end getreal
       ) ; end setq
       (cond
           ((/= pref "Yes")
           (while
               (<= cnt enum)
                           '(8 . "TEXT")
                           (cons 10 txpt)
                           (cons 40 (getvar "TEXTSIZE"))
                           (cons 50 0.0)
                           '(7 . "STANDARD")
                           '(71 . 0)
                           '(72 . 1)
                           '(73 . 2)
                           (cons 11 txpt)
                       ) ; end list
               ) ; end entmake
               (cond
                   ((= ldir "Up")
                   ) ; end cond 1
                   ((= ldir "Down")
                   ) ; end cond 2
                   ((= ldir "Right")
                   ) ; end cond 3
                   ((= ldir "Left")
                   ) ; end cond 4
               ) ; end cond
           ) ; end while
           ) ; end cond 1
           ((= pref "Yes")
           (while
               (<= cnt enum)
                           '(8 . "TEXT")
                           (cons 10 txpt)
                           (cons 1 (strcat ptxt (rtos cnt 2 2)))
                           (cons 50 0.0)
                           '(7 . "STANDARD")
                           '(71 . 0)
                           '(72 . 1)
                           '(73 . 2)
                           (cons 11 txpt)
                       ) ; end list
               ) ; end entmake
               (cond
                   ((= ldir "Up")
                   ) ; end cond 1
                   ((= ldir "Down")
                   ) ; end cond 2
                   ((= ldir "Right")
                   ) ; end cond 3
                   ((= ldir "Left")
                   ) ; end cond 4
               ) ; end cond
           ) ; end while
           ) ; end cond 2
       ) ; end cond
   ) ; end while
) ; end program
Hope this helps someone out! :)
Lee Mac you're learning fast.
Food for thought.
 (initget "Yes No")
 (setq pref (getkword "\nPrefix Text? [Yes/No]: <No>"))
 (if (= pref "Yes")
   (setq ptxt "")
 )       ; end if
 (while
   (and
     (setq snum (getdist "\nSpecify Starting Number: "))
     (setq enum (getdist "\nSpecify Ending Number: "))
     (setq incr (getdist "\nSpecify Increment Size [> 0.01]: "))
     (setq txtpt (getpoint "\nSelect First Text Base Point: "))
   )     ; end and
    (setq cnt snum)
    (setq lspc (getdist (strcat "\nSpecify List Spacing [> "
                        ) ; end strcat
               ) ; end getdist
    )    ; end setq
    (if (member ldir '("Right" "Left"))
      (setq ang 0.)
      (setq ang (/ pi 2.))
    (if (member ldir '("Down" "Left"))
      (setq lspc (- lspc))
       (while
         (<= cnt enum)
                         '(8 . "TEXT")
                         (cons 10 txtpt)
                         (cons 50 0.0)
                         '(7 . "STANDARD")
                         '(71 . 0)
                         '(72 . 1)
                         '(73 . 2)
                         (cons 11 txtpt)
                   ) ; end list
          ) ; end entmake
          (setq txtpt (polar txtpt ang lspc))
       ) ; end while
 )       ; end while
)         ; end program
Thanks Charles,
That make the LISP a lot more concise, whilst still achieveing the same result.
I couldn't figure out how to incorporate the prefix within the entmake function and still enable the user to decide not to use a prefix, without duplicating the entmake with use of a cond function - but just setting the prefix to "" in the alternative result of the if function accomplishes it nicely.
