Hi I have a block which contains dimensions and am wondering if it's possible for the dimensions to be hidden if the block is not selected? They are on a separate layer so I can hide them in the layer manager but it would be slick for them to autohide unless I select the block.
Anybody have a suggestion?
Thanks
John
Yes you can hide them if they are on a different layer using the freeze command. It can be found in the LAYERS 2 toolbar. Simply click the freeze on the toolbar click the dimensions and they should disappear.
You could make it a dynamic block with visibility states.
