cfrydawg Posted February 23, 2012 Share Posted February 23, 2012 is there a way to only show hidden lines on a shaft with a hole in it to only show quadrens instead of 30 lines around the arc. Quote Link to comment Share on other sites More sharing options...
Denimoth Posted February 23, 2012 Share Posted February 23, 2012 Set your DISPSILH variable to 0. It should help remove those unnecessary lines. Quote Link to comment Share on other sites More sharing options...
cfrydawg Posted February 23, 2012 Author Share Posted February 23, 2012 Sorry did not change a thing. I was allready set to zero Quote Link to comment Share on other sites More sharing options...
Denimoth Posted February 23, 2012 Share Posted February 23, 2012 Oops, my bad. Try setting it at 1. Quote Link to comment Share on other sites More sharing options...
cfrydawg Posted February 23, 2012 Author Share Posted February 23, 2012 Sorry did not help on 1 looks the same Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 23, 2012 Share Posted February 23, 2012 What is the current value of ISOLINES? Quote Link to comment Share on other sites More sharing options...
cfrydawg Posted February 23, 2012 Author Share Posted February 23, 2012 isolines 4 Quote Link to comment Share on other sites More sharing options...
Denimoth Posted February 23, 2012 Share Posted February 23, 2012 This is going to sound like a stupid question, but is your shaft made from an actual extruded circle? It appears your plan view shows the profile as more of a hexagonal shape. I realize this could be due to a number of things, such as not having done a regen before taking your screenshot, or other factors. But I'm seeing (barely) a bunch of other hidden lines that lead me to think your shaft isn't round. Quote Link to comment Share on other sites More sharing options...
cfrydawg Posted February 23, 2012 Author Share Posted February 23, 2012 Yes it is all round Quote Link to comment Share on other sites More sharing options...
Denimoth Posted February 23, 2012 Share Posted February 23, 2012 Is it possible for you to attach your DWG file here? It might help us figure out what's going on. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 23, 2012 Share Posted February 23, 2012 AutoCAD settings that affect 3D output. DISPSILH – Display Sihouette This setting affects the results of the Hide command. A setting of 0 displays tessellation lines. A setting of 1 suppresses tessellation lines. FACETRATIO – Quality of Rendered & Shaded Models This setting affects mesh density thus controlling the aspect ratio of faceting for cylindrical and conic solids. The settings are 0 and 1. A setting of 1 will increase the density of the mesh. FACETRES – Rendered Object Smoothness This setting affects both rendering and hide results. The default setting is 0.5. The max setting is 10. A lower setting results in a quicker render time but rounded edges will appear as a series of straight segments. A higher setting results in a longer render time but rounded edges will appear much smoother. ISOLINES – Contour lines per surface This setting affects the wireframe view but not the Hide or Render commands. Settings can range from 0 to 2047. The default setting is 4. SPLINESEGS – Segments in a Polyline Curve This setting controls the number of segments in a polyline curve. The settings range from 0 to 32767 with the default being 8. The higher the setting the smoother the appearance is of a rendered curve. Quote Link to comment Share on other sites More sharing options...
