BrianTFC Posted February 22, 2012 Posted February 22, 2012 Hi All, I was wondering if there was a lisp routine out there that when you pick a line it would put to circles in between the center of two lines 6" from each end? i've enclosed a file showing what i 'm looking for. Thanks, Brian Quote
Tharwat Posted February 22, 2012 Posted February 22, 2012 Does it mean that you want to insert a block called "holes" in a center of the selected line ? Quote
BrianTFC Posted February 22, 2012 Author Posted February 22, 2012 no. what i would like it do is draw the circles. Quote
Tharwat Posted February 22, 2012 Posted February 22, 2012 Things like this .... ? (defun c:TesT (/ ss i sn) (princ "\n Select lines :") (if (setq ss (ssget '((0 . "LINE")))) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (entmake (list '(0 . "CIRCLE") (cons 10 (mapcar (function (lambda (a b) (/ (+ a b) 2.) ) ) (cdr (assoc 10 (entget sn))) (cdr (assoc 11 (entget sn))) ) ) '(40 . 1.0) ) ) ) (princ "\n Nothing selected or not line(s) *** ") ) (princ) ) Quote
Tharwat Posted February 22, 2012 Posted February 22, 2012 I guess this is the one ..... (defun c:TesT (/ ss i sn p1 p2) ;;; Tharwat 22. Feb. 2012 ;;; (princ "\n Select lines :") (if (setq ss (ssget '((0 . "LINE")))) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (entmake (list '(0 . "CIRCLE") (cons 10 (polar (setq p1 (cdr (assoc 10 (entget sn)))) (angle p1 (setq p2 (cdr (assoc 11 (entget sn))))) 147. ) ) '(40 . 3.0) ) ) (entmake (list '(0 . "CIRCLE") (cons 10 (polar p2 (angle p2 p1) 147.)) '(40 . 3.0) ) ) ) (princ "\n Nothing selected or not line(s) *** ") ) (princ) ) Quote
BrianTFC Posted February 22, 2012 Author Posted February 22, 2012 no. but thats pretty cool..i need it to put two circles 6 inch from the ends of the blue line "when picked" in my drawing and have them centered between the blue and the green lines. Quote
BIGAL Posted February 23, 2012 Posted February 23, 2012 make a couple of simple changes to code (polar p2 (angle p2 p1) 147.)) change the 147 to 6" (polar p1 (angle p1 p2) 147.)) need to repeat entmake for other end Quote
pBe Posted February 23, 2012 Posted February 23, 2012 6" clear from both ends? What determines the radius of the circle? Quote
BrianTFC Posted February 23, 2012 Author Posted February 23, 2012 Here is the code that Tharwat wrote and with the help of Bigal i was able to get the holes to be 6" from the end of the line like i need but what do i change to get the circles to be 3/8" above the line. (defun c:wh (/ ss i sn p1 p2) ;;; Tharwat 22. Feb. 2012 ;;; (princ "\n Select lines :") (if (setq ss (ssget '((0 . "LINE")))) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (entmake (list '(0 . "CIRCLE") (cons 10 (polar (setq p1 (cdr (assoc 10 (entget sn)))) (angle p1 (setq p2 (cdr (assoc 11 (entget sn))))) 6 ) ) '(40 . 0.1875) ) ) (entmake (list '(0 . "CIRCLE") (cons 10 (polar p2 (angle p2 p1) 6)) '(40 . 0.1875) ) ) ) (princ "\n Nothing selected or not line(s) *** ") ) (princ) ) Quote
David Bethel Posted February 23, 2012 Posted February 23, 2012 I think I understand : [b][color=BLACK]([/color][/b]defun c:cirend [b][color=FUCHSIA]([/color][/b]/ ss en ed p10 p11 c10 c11 ang pan[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] p10 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] p11 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] c10 [b][color=GREEN]([/color][/b]polar p10 [b][color=BLUE]([/color][/b]angle p10 p11[b][color=BLUE])[/color][/b] 6[b][color=GREEN])[/color][/b] c11 [b][color=GREEN]([/color][/b]polar p11 [b][color=BLUE]([/color][/b]angle p11 p10[b][color=BLUE])[/color][/b] 6[b][color=GREEN])[/color][/b] ang [b][color=GREEN]([/color][/b]angle p10 p11[b][color=GREEN])[/color][/b] pan [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]< [b][color=RED]([/color][/b]* pi 0.5[b][color=RED])[/color][/b] ang [b][color=RED]([/color][/b]* pi 1.5[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]+ ang [b][color=RED]([/color][/b]* pi -0.5[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]+ ang [b][color=RED]([/color][/b]* pi 0.5[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] c10 [b][color=GREEN]([/color][/b]polar c10 pan 0.375[b][color=GREEN])[/color][/b] c11 [b][color=GREEN]([/color][/b]polar c11 pan 0.375[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"CIRCLE"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 10 c10[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 40 0.1875[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"CIRCLE"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 10 c11[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 40 0.1875[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]ssdel en ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
pBe Posted February 24, 2012 Posted February 24, 2012 (edited) Another (defun c:acir (/ circle _moveblk aDoc ss e ang pts ln p1 p2 cir1 cir2 entm_ entm gr code cord) (if (not (member "geomcal.arx" (arx))) (arxload "geomcal") ) (setvar 'osmode 0) (defun circle (Doc p r) (vlax-invoke (vlax-get (vla-get-ActiveLayout Doc) 'Block) 'AddCircle p r ) ) (defun _moveblk (flg ent bp np) (if (not flg) (vla-move (setq flg (vla-copy ent)) (vlax-3d-point bp) (vlax-3d-point np) ) (progn (vla-delete flg) (setq flg nil)) ) flg ) (setq aDoc (vla-get-activedocument (vlax-get-acad-object))) (if (setq ss (ssget '((0 . "LINE")))) (repeat (setq i (sslength ss)) (setq e (ssname ss (setq i (1- i)))) (redraw e 3) (setq ang (apply 'angle (setq pts (mapcar '(lambda (d) (cdr (assoc d (entget e)))) '(10 11)) ))) (if (> (setq ln (apply 'distance pts)) 12.0) (progn (redraw e 3) (setq p1 (Car pts) p2 (Cadr pts)) (setq cir1 (circle aDoc (setq uPt1 (polar (vlax-curve-getPointAtDist e 6.0) (+ ang (/ pi 2.)) 0.375)) 0.1875)) (setq cir2 (circle aDoc (setq uPt2 (polar (vlax-curve-getPointAtDist e (- ln 6.0)) (+ ang (/ pi 2.)) 0.375)) 0.1875)) (prompt "\nDrag & Pick Location rebar location:") (while (progn (setq gr (grread t 15 0) code (car gr) cord (cadr gr) ) (cond ((and (= 5 code)(> (c:cal "ang(p1,p2,cord)") 180)) (setq entm (_moveblk entm cir1 uPt1 (setq uPt1 (polar uPt1 (+ ang (* pi 1.5)) 0.75)))) (setq entm_ (_moveblk entm_ cir2 uPt2 (setq uPt2 (polar uPt2 (+ ang (* pi 1.5)) 0.75)))) T ) ((and (= 5 code)(< (c:cal "ang(p1,p2,cord)") 180)) (setq entm (_moveblk entm cir1 uPt1 (setq uPt1 (polar uPt1 (+ ang (/ pi 2.)) 0)))) (setq entm_ (_moveblk entm_ cir2 uPt2 (setq uPt2 (polar uPt2 (+ ang (/ pi 2.)) 0)))) T ) ) ) ) (vla-delete cir1) (vla-delete cir2) ) )(redraw e 4)(setq entm nil entm_ nil) ) )(princ) )(vl-load-com) (princ) It will not procees the lines if the length is less than 12 units. Edited February 25, 2012 by pBe add osmode 0 Quote
