cfrydawg Posted February 19, 2012 Posted February 19, 2012 Hey guys trying to make a frame on inventor. Hoping someone could do a quick vedio on what im trying to do here im going to post what the frame looks like in autocad. Im having troubles when i Make a part for the cross tube that connects the two side together I draw a line for a new part then place component and use frame generator on the line then becomes part of the side i used frame generator on previously. Keep in mind really new to inventor. I need to learn it for work. Quote
Bishop Posted February 20, 2012 Posted February 20, 2012 It sounds like you used Frame Generator to create one side of it, and then mirrored it or duplicated it otherwise? If you want this to all be a single frame, make the full thing out of sketches and then fill it in with Framegen. Don't mirror parts. Quote
