Leelee Posted February 16, 2012 Posted February 16, 2012 Hi there, hope someone can help me. I have been asked to create some blocks using attributes from a drawings and then save them into the 'blocks folder' with all the others, however when I go to create a block it will only allow me to save it to a file on my computer, and the blocks folder is not in there. Does anyone know where I am going wrong, it happens when I select to create a block and to save block to disk too Quote
Dadgad Posted February 16, 2012 Posted February 16, 2012 You will need to create a folder, named to suit, where you will store your blocks. There is no standard blocks folder. Once you do that, you will specify the path to that folder while you are creating your block. Very simple really, after you create the folder. Quote
ReMark Posted February 16, 2012 Posted February 16, 2012 You're not working over a network are you? Many companies have space set aside on their servers for storing blocks. The important thing to know is the name of the blocks' folder and the path to it. Quote
