SunnyTurtle Posted February 14, 2012 Posted February 14, 2012 QLeader not placing text centered to firstline Hi all I don’t know is this a problem with a lispmy company has set up or whether it is an autoCAD error. When I go to create a leader I type LE withis short on my system for QLEADER. You can then draw your leader or entersettings One I have drawn the leader I go to placethe text the problem I then have is that sometime my text appears below theline (pic 1) and sometime appears next to the line (pic 2) Pic 1 Pic 2 In the setting I make sure they are asbelow be sometime is doesn’t matter. (I think this has something to do withdrawing setup or annotation scale.) I have attached a file where I am havingthe problem as well as one that I am not having the problem QLEADER CORRECT.dwgFetching info... QLEADER ERROR.dwgFetching info... Quote
nestly Posted February 14, 2012 Posted February 14, 2012 Works fine when using the WCS, so it seems to be related to the UCS/Plan and AutoCAD using the wrong attachment when "West" is on the "Right" side Quote
SunnyTurtle Posted February 16, 2012 Author Posted February 16, 2012 Interesting a beleve you have found what is casuing the problem Looks like it a problem with AutoCAD i guess i will just keep manaul moving the text after using the comand Quote
