facing problem creating grid lines in revit
hi,
I am facing problem with the grid to maintain same label in both the sides as highlighted. please find the attached image.
please suggest if you have any solution.
regards,
nihar
hi if you click the grid line, you will get a little box pop up each end.
if you put a tick in both ends it will always label both ends of the grid...is this what you are after?
