BrianTFC Posted February 9, 2012 Posted February 9, 2012 Hi All, I have figured out to combine my three Lisp rputine but it still need works, i need to repeat the last part of the routine until right clicked and i can't figure it out it's driving me nuts. Can some one please help me. Also is there a way to use the the results from the first part of the routine to run the rest of the routine? Thanks, Brian (defun c:test1( / plines ; selection set of polylines ext ; extrnal point dist ; distance to offset poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") dist (getdist (strcat "distance <" (if olddist (rtos olddist) ;use old value as default "") ">"))) (if (not dist) (setq dist olddist)) ;reuse old distance if user press <Enter> (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "offset" dist poly ext "") (setq del (entlast) int (polar (cdr (assoc 10 (entget del))) (angle (cdr (assoc 10 (entget del))) (cdr (assoc 10 plist))) (* 2 (distance (cdr (assoc 10 plist)) (cdr (assoc 10 (entget del))))))) (command "offset" dist poly int "") (command "_.change" (entlast) "" "_p" "_la" (getvar 'clayer) "") (entdel del) (setq i (1+ i))) (command "undo" "end") (setq olddist dist) ;preserve current distance for next run (vl-load-com) (princ "\n>>> Select lines to extend/reduce <<< ") (if (and (setq lSet (ssget '((0 . "LINE")))); (setq lDel (getreal "\nSpecify : ")) ); end and (progn (initget 1 "Positive Negative Both") (setq doMode (getkword "\nSpecify direction [Positive/Negative/Both]: ") objLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex lSet))))); end setq (vla-StartUndoMark (setq actDoc (vla-get-ActiveDocument (vlax-get-acad-object)))); end vla-StartUndoMark (if(member doMode '("Negative" "Both")) (foreach ln objLst (vlax-put ln 'startpoint (polar (vlax-get ln 'startpoint) (vlax-get ln 'angle)(- lDel))); end vlax-put ); end foreach ); end if (if(member doMode '("Positive" "Both")) (foreach ln objLst (vlax-put ln 'endpoint (polar (vlax-get ln 'endpoint) (vlax-get ln 'angle)lDel)) ); end foreach ); end if (vla-EndUndoMark actDoc) ); end progn ); end if (vl-load-com) (if (and (setq cEnt (car (entsel "\nSelect Object: "))) (member (cdr (assoc 0 (entget cEnt))) '("LWPOLYLINE" "POLYLINE" "LINE"))) (progn (setq tStr (strcat "1@" (rtos (- (vla-get-length (vlax-ename->vla-object cEnt)) 5.38)) (strcat "''")) tBox (textbox (list (cons 1 tStr) (cons 40 (getvar "TEXTSIZE")))) tHgt (- (cadadr tBox) (cadar tBox)) twid (- (caadr tBox) (caar tBox))) (princ "\nPosition Text...") (while (eq 5 (car (setq gr (grread t 5 0)))) (redraw) (if (listp (setq sPt (cadr gr))) (progn (setq cPt (vlax-curve-getClosestPointto cEnt sPt) lAng (angle cPt sPt) bpt (polar cPt lAng (/ (getvar "TEXTSIZE") 2.)) tpt (polar bpt lAng tHgt) mPt (polar bPt lAng (/ tHgt 2.)) pt1 (polar bpt (+ lAng (/ pi 2.)) (/ tWid 2.)) pt2 (polar bPt (- lAng (/ pi 2.)) (/ tWid 2.)) pt3 (polar tpt (+ lAng (/ pi 2.)) (/ tWid 2.)) pt4 (polar tPt (- lAng (/ pi 2.)) (/ tWid 2.))) (grvecs (list -3 pt1 pt2 pt3 pt4 pt1 pt3 pt2 pt4))))) (if (eq 3 (car gr)) (progn (setq lAng (- lAng (/ pi 2.))) (cond ((and (> lAng (/ pi 2)) (<= lAng pi)) (setq lAng (- lAng pi))) ((and (> lAng pi) (<= lAng (/ (* 3 pi) 2))) (setq lAng (+ lAng pi)))) (Make_Text mPt tStr lAng)))) (princ "\n<!> Incorrect Selection <!>")) (redraw) (princ)) (defun Make_Text (pt val rot) (entmake (list (cons 0 "TEXT") (cons 8 (getvar "CLAYER")) (cons 62 1) (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) (cons 71 0) (cons 72 1) (cons 73 2) (cons 11 pt))) ) (princ) Quote
jammie Posted February 10, 2012 Posted February 10, 2012 Hi Brian, You seem to have a good handle on the auto/visual lisp functions. Could you please explain what exactly you are trying to achieve with your program? Regards Jammie Quote
Lee Mac Posted February 10, 2012 Posted February 10, 2012 I thought I recognised some of that code http://www.cadtutor.net/forum/showthread.php?36659-lisp-to-put-text-with-pline-leangth-above-line&p=241565&viewfull=1#post241565 Wow... that is old... Quote
BrianTFC Posted February 13, 2012 Author Posted February 13, 2012 Hi, When the lisp routine runs it does the first two parts just fine but when it gets to the last part it only lets me pick one line then ends the command, what i would like to do is pick as many lines that i need to and then right click out of the command. any thoughts. Quote
BrianTFC Posted February 13, 2012 Author Posted February 13, 2012 Hi Lee Yes Lee it does have a part of the PLLEN.lsp routine you wrote along time ago. Thanks to people like you we novice can learn how to write routines that work for what we need done. Many Thanks Lee. Brian Quote
fuccaro Posted February 14, 2012 Posted February 14, 2012 Lee Mac said: I thought I recognised some of that code ... I agree with you! http://www.cadtutor.net/forum/showthread.php?756-offset-multiple-objects Brian, you should post a short notice, if you barrow code from others. People spent their time to offer routines for free, at least leave their names for the posterity. Quote
BrianTFC Posted February 14, 2012 Author Posted February 14, 2012 Hi, I didn't mean to offend anybody. When i was combinding them together i just used the lines that pertained to the function of the lisp routine. Many apolyogies. I will remeber that for the future. Brian Quote
fuccaro Posted February 15, 2012 Posted February 15, 2012 No offense was taken, it was just a friendly word of warning. If you will keep that in your mind for the future, that's good. Quote
Dadgad Posted February 15, 2012 Posted February 15, 2012 BrianTFC said: Hi, I didn't mean to offend anybody. When i was combinding them together i just used the lines that pertained to the function of the lisp routine. Many apolyogies. I will remeber that for the future. Brian Brian, both fuccaro & Lee are right in the leading pack of those who have donated mind blowing amounts of code, expertise and energy to helping others on this site and elsewhere for years now. Presumably you noticed the reference to fuccaro's posted code too? :wink: Quote
fuccaro Posted February 16, 2012 Posted February 16, 2012 Thanks Dadgad! I think we can consider this issue belonging to the past. I just post here a link to a thread about copyright, and now myself I consider this subject closed. Quote
