Seath Posted February 9, 2012 Share Posted February 9, 2012 I cheated to make this drawing as I created in in AutoCAD and imported the parts into Revit Structure. My goal is to be able to create this exact drawing using only Revit. I know how to draw the tube steel and c-channel but I get lost after that. Any suggestions on classes books ect.. Quote Link to comment Share on other sites More sharing options...
Lee Roy Posted February 10, 2012 Share Posted February 10, 2012 First Step: Understand that Revit is not like AutoCAD. Second Step: YouTube Tutorials, Autodesk University Tutorials, Autodesk Tutorials Quote Link to comment Share on other sites More sharing options...
Seath Posted February 14, 2012 Author Share Posted February 14, 2012 I understand its not like AutoCAD and I understand that the drawings I create will not me the exact same. My question is how do I accomplish the attached in Revit is it possible? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 14, 2012 Share Posted February 14, 2012 Fist thing... have you loaded the proper structural member families? All your standard channel, bracing, and beams are already there. Got to load the Families before anything else is possible. Quote Link to comment Share on other sites More sharing options...
Seath Posted February 15, 2012 Author Share Posted February 15, 2012 I have. I was able to create the main part of the structure. The 4x4 tube, c-channel and the I beams were no problem. I set the necessary levels and played with the level offsets of the elements to get them where I needed them to be. Where I get stumped is for the base and the top panels. The top panels I assume I could treat like a slanted beam to get the slope I am looking for but my question is how do I create the "item" and them cut the design into it? Is this something I will have to create a family for? I assume it will be. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 15, 2012 Share Posted February 15, 2012 Have you dove into the 3D tools in the Family Editor? This would be all pretty simple using by simply drawing the Profiles and using the Extrusion method to create the 3D mass. Importing the necessary beams, braces, and channels would be a first step to get the foundation set. Once everything is complete, load the Family into the model and it's ready to go. Quote Link to comment Share on other sites More sharing options...
Seath Posted February 15, 2012 Author Share Posted February 15, 2012 Sounds easy enough. Next question we have an extrusion we use all the time for canopy designs. How do I create it and make it function as a beam would? I want to be able to use it as I would it I were laying out I-beams, ect. Quote Link to comment Share on other sites More sharing options...
