19cruthik68 Posted February 9, 2012 Posted February 9, 2012 Im making a shop drawing and it's already finished, when i tried to plot it in pdf or in plotter the other lines are not visible, is there a possible solution regarding this problem? Visual style control i tried all the things but still some other lines that drawn in 3d are blurred or not shown in the layout.can someone help me? Quote
ReMark Posted February 9, 2012 Posted February 9, 2012 What other lines are you talking about? Post the DWG file and someone here will take a look at it. If the file size is too large zip it or pare it down and try again. Quote
SR CAD Services Posted February 10, 2012 Posted February 10, 2012 Check if you have drawn the "missing lines" using the defpoints layer? if you have, then change them to another layer. Also, check the layer properties to see if plotting has been disabled, it will show a printer with a line through it if it has been disabled. Quote
