Qonfire Posted February 8, 2012 Posted February 8, 2012 Hello Im eager to know where in command "array" where do we include angle of array . (command "_array" primo "" "r" (fix(atof Nubrsprk)) (fix(atof Numbr)) sdist ldist ) Thanks Quote
David Bethel Posted February 8, 2012 Posted February 8, 2012 ARRAY uses orthogonatal ( 0 & 90 ) degrees of the current UCS for rectangular arrays. A work around is to rotate the UCS about the Z axis -David Quote
qzeek Posted February 8, 2012 Posted February 8, 2012 (edited) use the snap angle variable here is a quick array lisp you can use to get what your looking for. save the old snap angle and return when done. (defun c:QARRAY (/) (setq echo (getvar "cmdecho") osm (getvar "osmode") snpang (getvar "snapang") ) (setvar "cmdecho" 0) (setq SS (SSGET) pt1 (getpoint "\n Pick starting point of array: ") pt2 (getpoint "\n Pick ending point of array: " pt1) rotangle (angle pt1 pt2) offsetdist (getreal "\n Offset distance: ") copytimes (+ 1 (fix (/ (distance pt1 pt2) offsetdist))) ) (setvar "osmode" 0) (setvar "snapang" rotangle) (command "array" ss "" "R" "1" copytimes offsetdist) (setvar "cmdecho" echo) (setvar "osmode" osm) (setvar "snapang" snpang) (setq echo nil osm nil snpang nil ss nil pt1 nil pt2 nil rotangle nil offsetdist nil copytimes nil ) (princ) ) Edited February 8, 2012 by qzeek code tags Quote
qzeek Posted February 8, 2012 Posted February 8, 2012 IMA NOOOOOOOB!!! going to be a long year. Quote
