din_Dins Posted February 8, 2012 Posted February 8, 2012 Hello Couple days ago something crashed in autoCAD, and now when i select more lines or objects - i cant change colour in properties 1) If i select one line --- still in properties is showing By Layer (colour) 2) If i select more line --- this window where was By layer --- is not active anymore and i cant cahenge anything. I made 2 pictures - to understand better Hope someone know why happen like this Thanks in advice Quote
fahim108 Posted February 8, 2012 Posted February 8, 2012 Never saw anything like that before! My best guess would be to cross-check the same DWG file on another PC. If it shows the color column available there then you know your CAD needs some major repairing! Quote
SLW210 Posted February 8, 2012 Posted February 8, 2012 Can you post a portion of the file here? Quote
