dwillmschen Posted February 7, 2012 Posted February 7, 2012 does anyone know if it is possible to use a user defined parameter to drive a action parameter. I have several polar and linear stretch actions i would like to drive from one parameter. i think i have attached my dwg. the block name is config1 FOAM_DRAIN_PAN_DYN_BLOCK.dwgFetching info... Quote
irneb Posted February 8, 2012 Posted February 8, 2012 You can use a Lookup parameter. See the attached. Lookup DB.dwgFetching info... Quote
dwillmschen Posted February 8, 2012 Author Posted February 8, 2012 I don’t think a lookup parameter will work the drain pan size could be anything from 44" to 600" there would be to many combinations to use a look up parameter Quote
Grant Posted February 8, 2012 Posted February 8, 2012 The only other thing you can do is to do some visual lisp as you can change values in the list of the dynamic block. Type list enter All the values there you should be able to get to. Quote
